Page 14 of 21 FirstFirst ... 4789101112131415161718192021 LastLast
Results 521 to 560 of 820
  1. #521
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    if its bolt on i could be interested.
  3. #522
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,503
    Ian bolt on replacement. Equiv internally to a K04-23 with a nice low spool and a smooth power band
  4. #523
    May 2008
    perth
    1,197
    how much is that costing you?
  5. #524
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    I have to admit I'm very pleased with the performance of the Outlaw turbo on the purple car and would definitely recommend one. As far as a direct bolt on upgrade goes I doubt there is much that would better it to be honest.
  6. #525
    Apr 2004
    12,503
    $600 plus post, plus a donor K04 iirc
    I think in GBP it comes to a shade under 500 to my door, for a direct bolt in upgrade.
  7. #526
    May 2008
    perth
    1,197
    Are you thinking about getting the t3? If so I may be interested in the hybrid.
  8. #527
    Apr 2004
    12,503
    I cant unless i sell the hybrid first sadly. Its on its way to me, due early next week
  9. #528
    Oct 2007
    UK - Midlands
    2,223
    Just for info.
    T25/T28 turbos..
    http://www.norrisdesigns.com/products.asp?cat=50
  10. #529
    Oct 2007
    UK - Midlands
    2,223
    A few more bits arrived today..
    ...think I've got everything together now for the conversion so it's time to do a mock up TIP to check it'll all fit together (and fit in the engine bay).
    I've made a hybrid 3" MAF housing from a cheap 3" and a Bosch housing that I had spare. I'll get some pics up asap.
  11. #530
    jcb
    Sep 2005
    uk
    4,077
    what size filter?
    direct or through Badger?
  12. #531
    Oct 2007
    UK - Midlands
    2,223
    From a site I found on the internet..
    http://www.green-filter.co.uk/index.php
    Dimensions are:-
    O.A. height - 215mm
    Neck inside diam - 80mm
    Bottom cone diam - 140mm
    Top cone diam - 100mm
    Should be good for 350HP+ so it's all good.
  13. #532
    jcb
    Sep 2005
    uk
    4,077
    big sucka!
    same place I was looking
    you probably don't want to hear this but Bill Brockbank does them at discount rates...
    for future anyway...for when that one gets sucked into the turbo running at 35psi!
  14. #533
    132
    Which turbo was this ? A Derivative / hybrid of the K03 or K04 ?
    Quote Originally Posted by Lee Goodall View Post
  15. #534
    Oct 2007
    UK - Midlands
    2,223
    The turbo's a hybrid K04-015. Scroll products build them. It's Called an SP51X (outlaw) and it's a slightly higher spec than the K04 fitted to the TT 225 (K04-023?).
  16. #535
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    How much are they? As m my TQS turbo has died....
    Drizz Developments - Audi A4 Avant Quattro Sport
  17. #536
    132
    Yes, would be useful to know for future reference, how you get hold of scroll products ?
  18. #537
    Apr 2004
    12,503
    http://www.scrollproducts.com/indexe.html
    Speak to Sean Kinch, mention ASN, or Myself (mark) Doc, or Lee, he will be able to go through your choices for you. He is a nice honest guy
  19. #538
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Ill do that then!
  20. #539
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by Byzan A4 View Post
    ^Quote^ copied from earlier on in the thread.. gives you an idea of cost. As Byzan said you're best to contact Sean at Scroll Products to discuss your personal requirements.
  21. #540
    Oct 2007
    UK - Midlands
    2,223
    Got a posh self sealing T for the N75 to connect to. Fits nice and tight into a silicone hose..
    Here's a pic of the hybrid MAF housing. I used a cheap 3" diameter housing for the bottom cylinder, cut the neck (sensor mounted in the wrong position and the screw centres were different to the Bosch sensor), cut the neck from a spare Bosch housing, bonded together, sealed and primed. Will also be getting a couple of coats of black to finish it off when I get time..
  22. #541
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,453
    Where did you get these from Lee? Bill has an Ibiza in at the moment that is using these and has given me ideas
    <tuffty/>
  23. #542
    Oct 2007
    UK - Midlands
    2,223
    Got them from..
    http://www.revotec.co.uk/
    They were the cheapest I could find. Demon Tweeks and Merlin do them too but are a bit more expensive.
  24. #543
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    What's your idea mate?
  25. #544
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,453
    Planning a cold side relocation for my DV and rather than have to change all my hoses, these would be a suitable alternative. My custom TIP takes up a bit of room and its all tight around the DV plus I seem to eat N75 hoses so I want to tidy it all up.
    <tuffty/>
  26. #545
    Apr 2004
    12,503
    Will that gain you any performance?
    I need a MAF housing to play with too soon
  27. #546
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,453
    I might have to try a 4" housing
    <tuffty/>
  28. #547
    Oct 2007
    UK - Midlands
    2,223
    <tuffty/>
    I was considering relocating my DV when I install the Garrett as it's going to be a tight squeeze to get everything to fit in next to the turbo.. I don't think buying the worlds biggest air filter has helped much either lol.
    I presume the only benefit from relocating the DV other than the increase in space is that the heat from the turbo/exhaust can't affect the valves performance?
  29. #548
    Oct 2007
    UK - Midlands
    2,223
    <tuffty/>
    That's just greedy lol
  30. #549
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,453
    Purely logistical on my part, its very tight where I now have a 3" TIP and the only pipe that fits off the charge pipe to the DV is the OEM one and thats seen better days.
    I am relocating purely as its a better placement than for any other reason
    <tuffty/>
  31. #550
    gmx
    Feb 2009
    Sydney
    133
    I ended up using a MKIII VR6 housing.
    These will work for AEB/AJL "old style" MAF Elements.
    TT225/S3 will NOT work! They use a different element bolt orientation which is critical for MAF readings.
    I'm really interested if there's any further progress on the AGU/M3.8.3 ECUs hooked up to an AJL loom/cluster/engine.
    Any progress in the future, please post up.
    00 A4 1.8TQS GP MT AJL
    JHM SSK | FX300 + 16lbs FW | Milltek Dump back
    17*8 BBS RK | Deka ETX20L | Vogtland GT 575F/675R | H-Sport 35mm(F)/22.5mm(R) ARBs
    034 Engine Mts | Stern Snub/ Rear Diff Insert/Power Ring
    GT2871R Elim | Custom ME5 | 034 3" DP | 034 HFM | 034 TIP | ER Comp IC
  32. #551
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,311
    Quote Originally Posted by gmx View Post
    That will explain the issues lee had then! Presumably the TT unit will work for the later maf type?
    I was sure i'd read about a VR6 housing that could be used, but i wasnt sure, so thats good to know.
    TD5 Land Rover Defender build
  33. #552
    Oct 2007
    UK - Midlands
    2,223
    I managed to set the intake up today to check that everything will fit into place..
    The same turbo fitted to another engine used as a reference for positioning.
    My intake setup with 3" MAF, Filter and DV 'T' piece all in place.
    Filter sitting just below the line of the bonnet.
    DV will sit very close to the original position.
    The only thing left to finalise is the DP to exhaust connection. I'm not certain that the alignment is correct although it is fairly close!
  34. #553
    Apr 2004
    12,503
    That looks good mate, almost there by the looks.
    The n75 connection going onto a screw in barb?
    Also a thought,you breathing to atmos or using the PCV pancake?
    Just the exhaust connection to sort out
  35. #554
    jcb
    Sep 2005
    uk
    4,077
    you keeping all the vacuum and check valve nonsense or deleting it?
  36. #555
    Oct 2007
    UK - Midlands
    2,223
    Keeping all of the connection other than the PCV to start with. I'll bung a filter on the PCV/engine vent and see how it goes; if there's any sign that it's causing running issues then I'll connect it back up but if not I'll invest in a catch can and then vent that atmosphere.
    Yeah I bought one of those posh screw in barb connections for the N75 to fit into one of the silicone hoses in the intake.
    Got a plastic barbed connection that fits into a hard pipe (think I'll use one of the metal joining sections) for the connection from the EVAP valve thingamy-jig.
    Exhaust might be a pain as my DP doesn't line up with the exhaust system well enough to cut, join and sleeve successfully!?!
  37. #556
    jcb
    Sep 2005
    uk
    4,077
    I am taking the opportunity to get rid of all that vac/PCV stuff while I can be bothered
    http://www.audizine.com/forum/showthread.php?t=235106
  38. #557
    jamie226bhp's Avatar
    Aug 2009
    464
    Any benefit to removing all that junk other than less problem areas and looking tidier
  39. #558
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    And im guessing all thats the same on the B5? as the links for the B6?
  40. #559
    jcb
    Sep 2005
    uk
    4,077
    weight reduction!
    no actually I am just more interested in clean air coming in and simplifying the TIP.
  41. #560
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by jcb View Post
    weight reduction!
    I can see where you're coming from mate but I need my N75 connection for the map and it's only the connection from the EVAP that I'll be keeping if all goes to plan so it shouldn't overly complicate things.
Tags for this Thread
