Chris NottVolks Autos
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    Occasional starting problems
    Back in febuary i had my temperature sender unit replaced as i had a problem starting my car after work one night. This seemed to cure the problem untill this morning. At the time when i was trying to get it started i noticed a small amount of oil in with the first spark plug. Could this be the problem?
    Would it be the cam cover gasket that needs changing?
    Built in Germany, Perfected in England
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    That gasket will be the cause of the oil, not 100% it will have caused your starting problem tho
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    whats the nature of the non-start
    does it crank endlessly without catching?
    does it cough or almost catch but not quite?
    does it start then cut out instantly?
    Does it fix itself if you leave it a bit?
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    It cranked endlessly but didn't catch. To get it started i pushed the accelerator to the floor then turned the key which worked first time.
