Monster MotorsportChris Nott
Results 1 to 10 of 10
    Mar 2008
    143
    S4 avant towing weight help wanted
    Could some please confirm this for me.
    I don't have a hand book and the sticker in the boot is missing.
    The car is a 1999 S4 avant 2.7 biturbo
    I would like to know the tow weight, ball weight and the car weight and any other info you think i might need to know about the car when towing.
    Olly
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    Don't attempt any traffic light races.
    Mo power, mo problems
    Jun 2003
    World of my own
    9,813
    Alex Turner
    Mar 2008
    143
    If i read it rite it is braked trailer 1800kg and unbraked trailer is 750kg.
    Could any one confirm this from there hand book?
    jcb
    Sep 2005
    uk
    4,070
    tip:don't forget the trailer is there and take any sharp corners!
    Mar 2008
    16
    i don't have an s4 but can confirm the max weight for any unbraked trailer regardless of what is in front of it is 750kg
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    614
    Quote Originally Posted by OllyS4 View Post
    Olly
    If its any help I've retro-fitted a Genuine Accessory Votex detachable towhitch to my Avant (its a Westfalia item and is identical to the factory-fitted detachable towbar option) and the fitting instructions state
    "the tested drawbar ratio is 10.1kN.This equals for example, a trailer load of 1800kg and a permissable weight of 2400kg"....
    I've no idea what the 2400kg figure is all about though, I've always understood the limit to be 1800..........
    The ballweight is 75kg.
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
    Feb 2007
    Perthshire
    35
    i'll have a look in my manual, but i have towed 2000kg with my TDI avant and would not recommend it!
    Mar 2008
    143
    Thanks everyone. I hope to tow a mk2 golf (964kg had it weighed) on a light weight car tailer 130kg so should be well in and under the 85% rule.
    smitch's Avatar
    Sep 2006
    1,585
    The legality is that you cannot exceed the manufacturers towing limit. Unfortunately in most cases this is greater than the unladen weight of the car and people tow up to it not realising this is unsafe if you are inexperienced.
    The 85% rule is best kept to as if the trailer exceeds the weight of the towcar and you got into trouble it could turn in to a case of the tail wagging the dog.
    If you are experienced at towing and drive sensibly it is possible to tow more than the car weighs safely assuming that this is in line with the car manufacturers towing limits.
    I sold caravans for ten years and used to tow everyday and have regularly towed large caravans that outweighed the tow vehicle for great distances and never had any trouble what so ever.
    S4.
