Thread: will a
    Adam-D's Avatar
    Dec 2007
    wirral, merseyside
    458
    will a
    quattro interior, poss saloon from a 2000 a4 fit my pre facelift 1997 avant?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    The front will fit fine, but the rears will not be a straight bolt in as the split folding latches are in different places on the Avant
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Yeah the rear seats are different.
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    I had brackets made up so that I could latch my RS4 rears in my saloon, so I can't see it being too much trouble to do the same for saloon rears into an avant.
    You'd be best off getting hold of the latches from a saloon, probably from a breakers yard (or isn't there someone on here about to break one?). Once you've got those, take them to a local engineering firm and they shouldn't have any problems fabricating you some up.
    I used the highly technical method of cutting up an old cereal box and marking that to get the required dimensions! I think doing the same for saloon seats into an avant would be even easier because you have better visibility of the back of the seats.
    Another point to note is that the bits which go either side of the rear seat (bolsters?) are different for avant and saloons. The saloon ones 'overhang' by about 2" at the back. You should be able to cut them to fit though.
    Mo power, mo problems
