Results 1 to 8 of 8
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    VAG scanner tool.
    Found a VAG memo scanner (hand held OBDII socket powered) tool which has the following features:-
    Control Unit Information
    Read Fault Codes
    Measuring Blocks
    Clear Fault Codes
    Basic Setting
    Adaptation
    Single Reading
    Output Tests
    Code Module
    Login
    Service Oil Reset
    Code Modes
    Dealership Code Set
    Sound any good? I've not got a laptop so seems like a good alternative to VAG-COM.
    macca's Avatar
    Sep 2006
    Sussex.
    525
    i think pre 99 cars aren't fully obd2 compliant, so just check it works ok on these if your car is.
    1998 A4 1.8T Sport - For Saturdays
    2003 VW Golf MKIV R32 - For Sundays
    2000 Peugeot 406 HDi - For when it's raining
    1996 Kawasaki ZX7R - For when I'm late for work!
    Mods- Forge Dump Valve, The Engine Shop Power Plus based Engine (Low Comp. Forged pistons, Arrow H-Section Rods, Newman fast road cams, polished & ported head), 19" wheels, B&M Short Shifter, Greddy Turbo Timer, RS4 Grill, Weitec GTN coilovers, HKS modified air filter, Autobahn88 FMIC, ChippedUK custom map. Some Turbo mods ongoing.
    Oct 2007
    UK - Midlands
    2,223
    Really?!.. didn't know that. That must be why I'm having so many problems trying to get vagcom to work.
    Oct 2007
    2,597
    Quote Originally Posted by Lee Goodall View Post
    I don't see why - VAG-COM works on all models.
    How much is the other scan tool, out of interest?
    Oct 2007
    UK - Midlands
    2,223
    I'm just using an OBDII cable with vagcom but keep getting 'car not ODBII compatible if VW or Audi please try selecting individual controllers' then I try that and vagcom tries four times and then I get 'controller not available'.
    It's 79.99.
    Here's the link...
    http://www.talktomycar.co.uk/product...ders/mj009.htm
    Oct 2007
    UK - Midlands
    2,223
    Read Fault Codes
    Measuring Blocks
    Clear Fault Codes
    Basic Setting
    Adaptation
    Single Reading
    Output Tests
    Code Module
    Login
    Service Oil Reset
    Code Modes
    Dealership Code Set
    Doesn't actually state 'ODBII' but does say works with all VAG cars!
    macca's Avatar
    Sep 2006
    Sussex.
    525
    possibly incorrect cable, not sure.
    i think the stand alone unit will work
    Dec 2007
    11
    http://cgi.ebay.co.uk/U280-VW-Audi-S...QQcmdZViewItem
    I've just bought one of these and works well on my 98 S4
