Chris NottEM Tuning
Results 1 to 12 of 12
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    Audi 1.8T AEB engine oil light displayed on dash.
    Today after getting my car MOT'd i noticed the oil can symbol displaying on the dash. Stopped and checked oil. Found it to be just below max so topped up. On restarting the light never came on but it was noisey. Checked for any leaks all ok.
    Now the oil light has can back on after 2 miles so i am thinking maybe oil pressue. If it is the oil pump failing. How easy is it to replace the oil pump on these engines?
    Craig
    Audi A6 2.5 5Cyl tdi Quattro running 180ps 370Nm @0.9bar soon to be over 200ps
    AUDI URS4, URS6 and A4 1.8T breaking Lots of spares available at good prices. Large parts require collecting.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    get pressure checked as had the same with mine, had pump changed and it is a real pain as cross member in way of sump.
    mine turned out to be the pressure valve in the oil filter housing!
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    To get the pump out its a royal pain, but if you dont you end up with this
    I kept putting it off and blew it up before i got around to it. The crossmember isnt that bad to remove but you will need to support the engine and box using an engine crane or similar and then its around 12 bolts to drop it down and out. then the sump can be dropped out to get to the pump. Its only 60-70 part
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    Thanks for the info. It sounds like topend noise like the oil isnt getting up to the head. Where is the Pressure valve? Is it easy to change?
    How will i check the oil pressure as there isnt a gauge on my display?
    Craig
    Oct 2007
    2,597
    Lol, seems one of those days, huh.
    My oil light came on today, and she began a top end rattle. Aborted a day out with my girlfriend to Bluewater.
    Had to join the AA on the spot to get home - cost me 175. Got her home, and added a litre of oil - was between minimum and maximum, she's quiet now, but haven't driven her far yet.
    If the V6 is dead, I'll not bother buying an A4 R&D car, just begin installing the V8, and buy a cheap 100 runabout.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    I fitted a VDO pressure gauge when I started to get problems, I had one from my tuned g60 so just through it in as it was to hand, I think it is worth fitting for the piece of mind of knowing everything is fine.
    the pressure relief valve is located in the oil filter housing and I think it is easy enough to change, my local specialist did mine for me.
    best get pressure checked 1st.
    mine was ok when the engine was running at speed but at idle the lights came on. turned out this valve was dumping all the pressure as it was stuck open
    Quote Originally Posted by K7ERG View Post
    Craig
    2001 S3 (AMK)
    macca's Avatar
    Sep 2006
    Sussex.
    525
    came off my bike with a puncture the other day and had to do the 175 on the spot AA joining thing, felt painful but i was lucky to be alive, so not end of world.
    1998 A4 1.8T Sport - For Saturdays
    2003 VW Golf MKIV R32 - For Sundays
    2000 Peugeot 406 HDi - For when it's raining
    1996 Kawasaki ZX7R - For when I'm late for work!
    Mods- Forge Dump Valve, The Engine Shop Power Plus based Engine (Low Comp. Forged pistons, Arrow H-Section Rods, Newman fast road cams, polished & ported head), 19" wheels, B&M Short Shifter, Greddy Turbo Timer, RS4 Grill, Weitec GTN coilovers, HKS modified air filter, Autobahn88 FMIC, ChippedUK custom map. Some Turbo mods ongoing.
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    same fault i ha don my aeb and it was oil sump feed..the filter was blocked to hell about 60.00 for part but it a ball acher to get to it
    Modified primera :-)
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    Going to try new oil and filter as i have it here first to see if it helps. If not time to take the sump off and have a futher look.
    Craig
    Oct 2007
    2,597
    Hope it's all ok - mine turned out to be a leaking coolant expansion tank, it ran so hot, the oil got pretty thin, and of course at that oil temperature, pressure dropped.
    Just waiting for a new coolant tank and cap to be delivered this morning, then that should be it.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    k7erg, when you take oil filter off, remove oil cooler and 3 bolts holding housing to block, when i did this the valve fell out ! had come loose so was being bypassed, i screwed it back in tight, changed oil, tappets quietened down and i never got a light again, i had even bought new pump but didnt need it
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    ok cool i will try this first.
    Thanks for the info mate.
    Craig
