Chris NottMonster Motorsport
Results 1 to 7 of 7
    Mar 2004
    16
    brakes and clutch upgrade
    i want to upgrade brakes and clutch on a 1996 1.9tdi 110bhp. i am going to install a corrado or g60 clutch for about Ł100. is this ok? what brake pads and discs shall i get? shall i get S4 pads and discs?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,312
    Re: brakes and clutch upgrade
    Um..why would you want to fit S4-spec brakes on a 1.9TDi?
    Mar 2004
    16
    for better braking. or any other good brakes? reccomend me some good cheap brakes?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,312
    Cheap is not a good idea, when it comes to modifying the brakes. Cheap ones might be different but that doesn't mean they'll be better than what's on the car already. Genuinely good brakes cost a lot of money. The point is..do they really need modifying? This is not a high performance car. I've driven quite a few TDis & the brakes seemed pretty darned good to me as they were. If I'd test-driven a car on which I thought the brakes weren't up to the job, I wouldn't buy the car!
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,824
    If you read this thread on breaks it should help, I fitted what I regard as a budget option due to the current exchange rate.
    Link to break upgrade
    Aberdeen
    153
    Youngdriver,
    Where are you posting from? It helps us give you the right advice when we know your details, car location etc.
    First off. I don't understand why you want to upgrade the clutch and the brakes. Are you having trouble with either at the mo?
    There is little point in fitting the S4 brakes if they will even fit a 110bhp dti while the larger diameter disks are more powerful, they are still not up to serious use.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,312
    [ QUOTE ]
    Patrick said:
    Youngdriver,
    [/ QUOTE ]Exactly my point. If you've got money to spend on the car, you can spend it much more wisely than that!
