AH FabricationsEM Tuning
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,923
    Boost dropping off?
    I've found when giving my A4 a bit of right foot the boost peaks at about 0.8bar and once in 2nd and third tails right back to 0.4. Soggy wastegate actuator perhaps?
    If it was one of my old Fords that's the route I'd take but the Audi has the N75 valve to control things so don't want to go swapping bits out without being sure.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    Sounds like a boost leak.
    Mo power, mo problems
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    check dump vlave and pipe etc i had VERY simalr problem with my 14 when first got it after replacing pipes, clips, dumpvlave, odd gaskets replaced ht 8psi and held like it should
    Modified primera :-)
