AH FabricationsChris Nott
Results 1 to 7 of 7
    Mar 2008
    Question NO heat at all ever
    The heaters in my 98 A4 have not worked since I bought the thing, a mechanic had a look and flushed the hoses but still nada, can anyone give me some fault finding advice or am I being to general with my problem, any help would be appreciated
    Stewart
    Oct 2007
    2,597
    Has it got climate control? Make sure the control flaps are working. I'd get it checked with VAG-COM or similar.
    If the temperature drops at sustained cruising speeds, then the thermostat is suspect, stuck open, and allowing the engine to over cool.
    Mar 2008
    Thanks Siena will do
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    MY CLIMATE CONTROL has a mind of its own it goes up and down altering the fan speed?
    Modified primera :-)
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    On pre-facelift sometimes one of the temp sensors (there are two in the cabin) can get clogged up. It's the little mesh of holes on the climate unit. Get an old tooth brush and give it a good clean.
    Mo power, mo problems
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    ahhhhhhhhhhh i see i dint know taht it also seems to be blowing warm all the time even at 18 c i will try that
    joost's Avatar
    Nov 2005
    Lancs
    1,166
    Quote Originally Posted by AUDI TURBO
    Mine's doing the same - like Siena said, it's most likely the temp control flap sticking. Allegedly, it's a dash-out job to sort hence why I've not even attempted it yet.
    Mine changes from sauna to cryogenics chamber at the drop of a hat. I'm keeping warm at the mo so I'm not overly fussed. Knowing my luck it'll try to freeze my moobs off in the morning.
    The fan speed may be due to the fact that the climate unit won't blow through certain vents until the engine has started warming up. Once the engine temp starts increasing, the fan speed will increase too IIRC.
    Justin
    2001 VW Golf 2.3 V5 (170) Highline, Indigo Blue - standard, for now...
    A4 (B5) SE with a few slight amendments here and there (sold)
