Chris NottBadger5
Results 1 to 8 of 8
    Dec 2007
    26
    Just ordered this.. engine saver!
    I went on here and PM the guy running it. ( told him UK.. he will do a deal if you know what I am saying!) not going for a direct port.
    this is a link for the old group buy, if you register there is a new on, I had a look at going direct but this is way cheaper.
    http://www.srtforums.com/forums/f210...up-buy-375918/
    but getting this "Vari-Cool Stage 2 with Smart Injection kit 2504,
    with a trunk mount".
    I have a friend who has the same kit and it is way above the rest. we have seen mass temp drops when running it just on water, and of course even bigger with a mix
    Thing I like is it is fully progressive, I am having it more for engine protection than power ( bring the EGT down)
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    imo if you need water injection there is something wrong with the rest of your setup. Ie your charge temps are too high due to insufficient intercooling.
    Its bodge and will most likely reduce power output for a given boost level.
    what are your charge temps at the moment and what else have you done to improve the existing intercooling setup?
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Whats this about, the link goes to a login screen.
    Is this about aquamist systems?
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Dec 2007
    26
    sorry about the link, this is an old link http://www.srtforums.com/forums/f210...up-buy-375918/
    you have to reg on the site to see the new group buy.
    Sorry, this is a pukka system, I have been looking around for a long time and this thing is so clever... the guy above import racing or something, is really keen with the prices.
    this is the direct link http://coolingmist.com/detailmain.aspx?pid=2504 but the group buy is well better.
    water/meth with the boot tank last for ages, if you want lower EGT its good.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    These are quite old technology, that doesn't make them any less effective though.
    Water mist injection actually aids combustion in high performance cars, water is after all only oxygen and hydrogen.
    Chris
    See my images @
    Dec 2007
    26
    old technology!!!!!!!!!!!
    they have the most up to date lits there is?????????????
    direct port...3D sequential
    taking readings from, charge temp, throttle angle, and loads of other things...
    Have you really looked close at the kits..... no sir they are lot old... but the best of the best, I have really looked into this.. all of the aqua, snow, devils, the lot.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    The kits maybe new but the concept is over 40 years old.
    Chris
    See my images @
    Jul 2007
    341
    Quote Originally Posted by A4Quattro View Post
    its well over 40 years old, being used on supercharged piston engined fighters in ww2. its a very old concept, but then, so is the internal combustion engine its self!
