AH FabricationsChris Nott
Results 1 to 18 of 18
    Road Razor's Avatar
    Tyne & Wear
    390
    Short shifter installed
    I've just installed a B&M short shifter. Putting everything back together was most time consuming part because of the limited workspace in the drive shaft/housing. But it's brilliant kit, I'd definitely recommended to anyone.
    Just one problem though, the stick keeps falling downwards through the pivot (see pic below). I realise there's a retaining ring missing when I assembled the shifter as per the instructions. So far I have to lift up the stick everytime I select a gear.
    I might have to find something that sits above the pivot to stop the stick falling or find something and wrap round it. Or use jubliee clips.
    Any other suggestions?
    A4 2.4 V6 2000.
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    Is the spring provided not enough to hold the shifter up? I found the opposite with my kit, was hard to push the stick down to get reverse, took it off after a year cos I could no longer select reverse!
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    Road Razor's Avatar
    Tyne & Wear
    390
    There's no push down mechanism to select reverse because in the facelift version you just select reverse just like any other gear. There's springs provided but it's only for the pre-facelift A4.
    A4 2.4 V6 2000.
    Jul 2007
    341
    Quote Originally Posted by Road Razor View Post
    i think that could be your problem.... my facelift i have to push down the stick.
    Road Razor's Avatar
    Tyne & Wear
    390
    Quote Originally Posted by nickkeyser View Post
    So the facelift does have a push down stick. That's interesting to know.
    Anyway the instructions does cater for both types, one which have the push down reverse, and one that doesn't. So it appears that there are two types of shifts regardless if its facelift/pre-facelift.
    A4 2.4 V6 2000.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    When its pulled right up is there a groove for a clip? Its been years since i fitted mine
    Road Razor's Avatar
    Tyne & Wear
    390
    No there's no groove when pulled right up. I think a retaining ring would've fixed this problem but I'll try and figure out another alternative. Probably get some anti-slip rubber to wrap round the stick then clamp it. Thanks for your input guys.
    A4 2.4 V6 2000.
    stapo69's Avatar
    Mar 2007
    966
    I thought facelift and pre were the same, my mates facelift had push down reverse.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    There was a groove in my short shifter that needed a circlip to hold it in place.
    Mo power, mo problems
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,087
    My 96 A4 has puch down revers but my 97 A4 didn't :?
    I've been looking at quick shift kits fo myine and found VAGtech do one fitted for 140
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,850
    I lost my clip to hold it in place when I was installing mine so in the end I used a jubliee clip and it's been good for near on 2 years and my kit was one of thouse ebay jobs which I understand is just the same.
    The face lift 1.8T do not have a pushdown Reverse but maybe the S4's do.
    Turbo Lag FTW's Avatar
    Hate those none insured you know who types
    Feb 2007
    Carlisle, Cumbria. Not Geordie nor Scotch!
    233
    My mothers facelift requires pushing down to get reverse, as does my prefacelift, but tbh mine is kinda worn and will go into reverse with minimum effort
    Audi A4 1.8T Sport
    Road Razor's Avatar
    Tyne & Wear
    390
    I've managed to fix the issue by wrapping sticky velcro (rough part) around the stick then clamp it with jublibee clips.
    It's amazing how making this simple short shifter upgrade makes a difference and improves my enjoyment to the car. No more wobbly long throw.
    A4 2.4 V6 2000.
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    or you could just make you own
    TopGear Stockport / Longlife Exhausts /
    www.TopGearStockport.co.uk
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    do they make this for a a4 1.8 turbo 1996????????
    Modified primera :-)
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    you can do it urself mate there is a write up on audi-world
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    you can make yourself that intresting
    Aug 2007
    87
    my 99 a4 doesnt have push down for reverse
