Badger5JMB Retrofits
    Adam-D's Avatar
    Dec 2007
    wirral, merseyside
    458
    passenger door problem
    when my passenger door is closed from the inside it never closes properly,
    if yo close it from the outside wheli keeping pressure on it, it does,
    but there has to be somthing wrong, any ides,? its really annoying and i cringe every time it has to be slammmed shut
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    sounds like its out of line the catch might need a little adjustment or the door has dropped but this can be ajusted at the hinge.
    TopGear Stockport / Longlife Exhausts /
    www.TopGearStockport.co.uk
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Ditto what Craig has said. It's quite common for the doors to drop on these. Only takes one fatty pulling themselves out of their seat using the top of the door frame to misalign it!
    Check that the latch is on tight, use some thread lock on the bolts if it's not. You can also try lifting the door by just giving it a good heave to bring it closer to straight.
    Mo power, mo problems
    Adam-D's Avatar
    Dec 2007
    wirral, merseyside
    458
    right ill have a look see if i can rectyfy the problem
    simonwjones's Avatar
    Aug 2005
    staffs uk
    351
    I get this occasionally on my A6.
    Its the door lock asembly. I simply spray WD40 into it and problem goes away.
    Simon
    A6 3.0TDI Quattro Avant Le Mans
    A6 2.5tdi Quattro Sport 180 Sadly Missed
    A6 1.9tdi Avant ................. Gladly missed
    A6 2.8 Quattro .................. Sadly missed
    Quattro 2.8 Coupe ............. Sadly missed
    SatNav, BT, AMI, DAB
    Jimbo.King's Avatar
    Oct 2006
    Leeds
    183
    My passanger door is suffering from "lack of use", due to this the door hinges have gone tight and so have the little rollers that keep it open in the 4 different stages, even with oil/wd40 it is still suffering but not as bad.
    When someone gets in and is not used to shutting the door it only closes on the first latch, this is down to tight hinges and people not wanting to slam the door.
    Open the passanger side door and feel if it is tight on the hinges compared to the drivers door.
    You could be suffering with the same.
    2007 A4 3.0tdi Quattro S-line, Lava Grey Pearl, 229+bhp, 6 speed manual, Cruise control, Auto wipers/lights, Parking sensors all round, RNS-E Sat Nav, Heated Volterra leather, Adaptive Bi-Xenon plus headlights, Bluetooth phone prep/voice control, DRL, i-Pod dock, Coming home lights, A4 B5 front spring seat mod, LED DRL/side light/numberplate lights, Window tints, Cupra R front splitter, Black front grill, 3.5" custom tail pipes, 8.5x19 Calibre Excalibre wheels running 225/40/19, ET30-R ET35-F.
