Results 1 to 16 of 16
    Mar 2008
    Northampton
    Airbag light issue
    Hi all - first post from a newbie S4 Avant (1998) owner here.
    Airbag light is showing on the dash - have noticed that you can pick up reset tools on ebay fairly cheaply. Anyone ever used one of these? Do they work? Any info appreciated.
    Rob G
    951
    951's Avatar
    Feb 2007
    North east
    493
    Mines allways been on,its usually the connection under the drivers seat,its been reset once but came back on after a week !!
    A4 Avant 1.8T Sport (183 bhp).
    SmoothAssault's Avatar
    Will design for mods
    Dec 2007
    Cambridgeshire
    787
    Audi Sunderland reset mine for about 12 and let me drive around in a brand new A6 while they were tinkering. Mine hasn't come back on since and that was almost a year ago now.
    FOR SALE: Eibach Sportline Springs from B5 A4. £50 - PM for details.
    Jun 2003
    World of my own
    9,813
    Just remember if the light is on all your airbags are disabled regardless of whether there's a fault or not.
    Alex Turner
    Jun 2003
    World of my own
    9,813
    Alex Turner
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    You're better off buying a cheap Vagcom cable off eBay so you can reset the light yourself, once you've fixed the problem of course.
    Mo power, mo problems
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    reset/code readers will only reset light if problem is fixed, usual problem seems to be loose connectors under seat, i have a code reader and a genuine vag-com dongle, code reader gives same results 9/10 times and you can keep it in glovebox
    Mar 2008
    Northampton
    Thanks for everyones replies - will get it properly looked at. Loving the car BTW - should have bought one of these years ago!!
    Milton Keynes UK
    248
    Rob,
    Some info for you.
    pre 2000 cars do not use gold plated connectors on the airbag wiring harness and as such you will receive High Resistance faults showing up on the code reader.
    The main culprit is the connector under the drivers seat. There will be 2 connectors, one with 1 wire and one with 2 wires.
    The best thing to do to prevent this code from coming up again is to cut off the connector and directly solder the wires together. I have done this on my 1998 and the code has never come back!
    Make sure the ignition is not switched on while you are doing this + earth the soldering iron to the chasis to prevent any accidental airbag deployments. Mose soldering irons have the ability to earth them out.
    VAG-COM USB cable can be purchased frrom ebay Seller - AlphaBid, for about 20 including postage from Canada. VAG Version 409.1 is a free download as shareware and can reset the airbag light.
    Jim.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,500
    Pretty much what he said ^^
    I am lucky as when i swapped seats i soldered the new style connectors on too
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    anyone?
    Apr 2004
    12,500
    Yup thats him
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    i got one of those but would not read module , full real vagcom had no problems
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    i wanted to know if this was the right one for my car and will it work with vista? this is the reply i got back from alpha bid
    Our USB and Serial port Vag-Com Cable for version 409 will work on all VW, Audi, Seat and Skoda Vehicles unless the vehicle is on the CAN-BUS System. If your vehicle is an older one with the 2x2 connectors, you may add our 2x2 adapter. Check for a label under the hood to see if your vehicle is CAN-BUS. Many of the newer models use this CAN-BUS system. We do sell CAN-BUS enabled Vag-Com Cables here: http://www.alpha-bid.com/product222.html
    As far as we know, the software is only compatable with the Operating Systems listed in the item description
    is mine a CAN BUS or not?
    and will this work with vista?
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    hi, your car is not can bus, check ross tech (they make vagcom) site for info on vag-com working on vista
