    marky_g
    Dec 2007
    Costa del Essex
    47
    engine mounts going
    is this a common fault???
    is it relatively easy to fix?
    what sorta money am i lookin at to put it right?
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    well the front snub mount is very easy to change and is around 40 quid for an uprated one.
    the two side engine mounts are easy to change as well i uprated mine to rs4 items alot more stiffer.
    regards
    craig
    TopGear Stockport / Longlife Exhausts /
    www.TopGearStockport.co.uk
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    i changed mine like for like £28.78 from local vw/audi specialist
    Modified primera :-)
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    did you notice much of a difference with the rs4 ones? How much did they set you back and are they a like for like fit? Cheers mate.
    Quote Originally Posted by billybravo
    regards
    craig
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    i think they was around £100 or so and they fitted just like the old std mounts
    you do get a bit of engine noise in the cabin now but they are way better than std items.
    ive heard that the 034 motorsport uprated mounts are even stiffer than the rs4 ones
