Volks AutosAH Fabrications
Results 1 to 9 of 9
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    a4 1.8t rear brakes
    hi there, i have a FWD 1.8TS A4 B5, and am looking at upgrading the rear brakes
    The car is currently standard however im looking to fit 312mm disks to the front in the near future. The rear brakes are however pretty knackered and will need replacing soon. I think at least one caliper is possibly siezed and the disks are pitted badly so will all need replaced. I'm wondering if its possible to upgrade them while im there with S4 or A8 rear parts.
    I've found a conversion guide detailing fitting the A8 carriers to the quattro A4 with S4 calipers but it doesnt mention the FWD cars and im not sure if these will fit a FWD car?
    If the A8/S4 stuff wont fit then is there any other combination that will work?
    Thanks in advance
    Kevin
    "Stick a V8 in it!"
    15,379
    bump.
    18 views and no replies? someone must have an idea if the s4/a8 parts fit a FWD or if not something that will fit a FWD car!
    kevin
    Oct 2007
    2,597
    I too have S8 Brembos to go on the front of my B5 quattro, the set-up should be the same for any B5 FWD model.
    They are radial mount, so going to get suitable MOVI-IT style carriers.
    "Stick a V8 in it!"
    15,379
    hi there, i think we've got crossed wires slightly, im referring mainly to the rear brakes...
    for the front i'm just going to use the TT carriers and keep the original calipers with the A6/A8 disks
    as for the rear ive done some looking and discovered the FWD B5 uses a disk and hub integrated into one, every other model uses a seperate hub and disk including B6> FWD cars, so while the calipers may well fit the car the disks wont, and as the hub is integrated its basically impossible to get a larger disk for the rear
    looks like i'll just have to replace whats there with standard stuff.
    Next question, anyone know if the later alloy calipers will be a streight swap for the early cast iron ones?
    macca's Avatar
    Sep 2006
    Sussex.
    525
    possibly an expensive option, but try calling Hi-spec to see if they have a configuration for the rear. i'm going 330mm AP's on the front eventually and am leaving the rears as standard.
    1998 A4 1.8T Sport - For Saturdays
    2003 VW Golf MKIV R32 - For Sundays
    2000 Peugeot 406 HDi - For when it's raining
    1996 Kawasaki ZX7R - For when I'm late for work!
    Mods- Forge Dump Valve, The Engine Shop Power Plus based Engine (Low Comp. Forged pistons, Arrow H-Section Rods, Newman fast road cams, polished & ported head), 19" wheels, B&M Short Shifter, Greddy Turbo Timer, RS4 Grill, Weitec GTN coilovers, HKS modified air filter, Autobahn88 FMIC, ChippedUK custom map. Some Turbo mods ongoing.
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    Why do you want to upgrade the rear brakes ?. I can see the point in upgrading the fronts if you have to, but on a fwd most of the braking force is on the front not the rear. Unless you are planning a massive power upgrade I would just use standard components on the rear (maybe upgraded pads). The last thing you want is to go too far in upgrading the rears.
    "Stick a V8 in it!"
    15,379
    Quote Originally Posted by mwarrey
    as i said in my original post, if i'm replacing everything anyway and there was a cheap upgrade available then i'd do it
    the braking force distribution on a RWD car is no different to a FWD car, they're both massively biased to the front, however if you upgrade the fronts you shift the bias more to the front than before, this means your more likely to lock the front brakes (ie trigger the abs) than if the car was balanced
    i plan to upgrade the fronts and was simply looking to see if it was possible to upgrade the rears similarly.
    remember audi upgraded the rears on the S4, and they wouldnt spend the money doing that for no reason.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,087
    Actually there is usually quite a difference in braking bias between FWD and RWD cars. On FWD it can be as little as 10% of the braking whereas RWD is typically more like 20-25%
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    Quote Originally Posted by aragorn
    The reason Audi upgraded the brakes on the S4 is because it has close to twice the power of a 1.8t, its 4wd and is heavier.
    It can make sense to see if you can upgrade when replacing worn out parts, all I am saying is don't get caught up in upgrading just for the sake of it, especially when it is unlikely to make much difference. You may be better spending elsewhere.
    I have fallen into this trap myself in the past. Spent a small fortune upgrading the rear drums on a mk1 GTi to disks. Looked a lot better and impressed other owners but did little in terms of extra braking over the original drums. Also saw a post recently of someone who upgraded their rear brakes to rs4 spec before doing anything to the fronts.............
