AH FabricationsSky Insurance
Results 1 to 7 of 7
    Apr 2004
    6
    Bad CV joint? (my first post)
    hello everyone this is my first post but i am not new to audi's or this forum.
    Lately it sounds like my 97 A4 1.8t (not a quattro)has all terrain tires on it. the ride is very rough and gets rougher if i turn the steering wheel slightly to the left or the right. has anyone experienced this? my tires are all inflated properly. i am sure the tires are not the issue. is it a bad cv joint?
    thanks in advance for the help
    Apr 2004
    6
    Re: Bad CV joint? (my first post)
    cmon...a little help please
    could it be a bad control arm...is the cv joint part of the control arm?
    Apr 2004
    41
    sounds like a wheel bearing to me.best way to check is to raise the vehicle and spin each wheel by hand and listen.it is possible to feel worn bearings through the bearing carrier/susp upright whilst spinning the wheel by hand.
    Feb 2003
    Lincolnshire/Bournemouth
    739
    rougher...like bumpy?
    Apr 2004
    41
    dont quite get you.is it speed related
    Apr 2004
    6
    it is speed related and the faster i go the louder the ride is. it sounds like its the tires but they are fine. the dealer told me to check my power steering fluid but that was good too. it isnt something that is stopping me from driving but just a little annoying b/c the ride used to be so smooth.
    Apr 2004
    41
    it could still be tyres.certain brands go knobbly on the inside edge.you could feel his by rubbing your hand over the inside edge.ive had a few cars with this fault.also ive had an out of shape tyre.try raising the vehicle and spin each wheel and view each tyre from the rear at the bottom and look for the tread jumping.
