EM TuningMonster Motorsport
Results 1 to 18 of 18
    Road Razor's Avatar
    Tyne & Wear
    390
    Question about spare wheels
    Just out of curiosity, what type of spare wheel do you guys carry in the trunk? I'm under the assumption that if someone bought 4 sets of larger wheels to upgrade from factory standard ones what contingency do you have if you had a puncture?
    Even if you kept an OEM as spare wouldn't this affect the roll radius because of different wheel diameters?
    Space savers is probably another option but again this issue about roll radius.
    Do you carry a tyre repair kit?
    Or do you not bother with a spare wheel and leave the trunk empty? A guy I know never carries a spare wheel because he wanted to save weight and he's never had an incident where he had to use a spare, hence reckons it's a very low risk.
    A4 2.4 V6 2000.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    I have a steelie in mine as a spare, but the rolling radius is the same as the 18's i am running, but a bit slimmer. I worry too much just carrying the tyre weld, so have a spare and tyre weld
    Oct 2007
    2,597
    I've also got a standard steel as a spare.
    807
    doesnt realyl matter just stick any wheel on just to "Limp" home
    Dec 2007
    Brighton - well Hove actually
    71
    my alloys are 16" & the spare is 15"..
    i dont think a 16" will fit in the wheel well tbh..
    2.8 30V V6 193PS
    Gone. But not forgotten
    Now
    A4 2.5tdi 180 quatro
    hiltoa's Avatar
    VAG erfahren
    Jul 2006
    on the edge
    299
    My spare is an OEM 17" with 225/45 tire and just fits in the well - a 245/40 tire doesn't fit - as I found out when I got a puncture last week...
    Nothing feels fast for long...
    2004 Audi Allroad 2.5 TDI L.E.
    Ebony Black.
    1991 VW Golf GTI 16v
    Tornado rot.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    my spares a matching oem (b6)17" with 235 45 tyre, but wont fit in wheel well without letting 15psi out of it so i need to carry a 12v mini compressor
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    I've got RS6+ brakes up front, so needed something with suitable clearance for the calipers.
    I managed to get a single 18" Avus (B6 S4) rim from a breakers. It's quite common for one or two wheels out of a set to get damaged beyond repair, so worth calling round the breakers yards to see if they have any 'loose' ones.
    Last edited by Blue_Thunder; 23rd February 2008 at 21:07. Reason: I spell like a spaz
    Mo power, mo problems
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    I have the standard 17" avus in my boot still even though I'm running 19s now, but I'm sure it'd get me home! And a couple of tins of tyre weld just in case! But i've always been a bit like, "i'll cross that bridge when i get to it!"
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    my spare is in the bin along with the spare wheel well i removed it as i wanted a flat trunk for a racing fuel tank
    tyre weld is always in the glove box
    regards
    craig
    TopGear Stockport / Longlife Exhausts /
    www.TopGearStockport.co.uk
    treblesykes's Avatar
    Nov 2004
    york
    688
    surely all wheels will fit in the spare wheel well regardless of rim diameter
    hiltoa's Avatar
    VAG erfahren
    Jul 2006
    on the edge
    299
    My issue is girth (!)
    A 245 tyre is too wide to allow the wheel to hook under the small lip at the rear and slip down the front edge of the well.
    Ebony Black.
    Tornado rot.
    Road Razor's Avatar
    Tyne & Wear
    390
    So if I had a puncture with my 17"s I suppose it doesn't matter if I replaced it with a 15" stealie or space saver spare wheel.
    A4 2.4 V6 2000.
    Feb 2007
    Liverpool
    1,693
    You wouldn't want to drive it too far if you've got Quattro. Think the manual recommends no more than 40 miles. It winds the diffs up due to the different rolling radius.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    I have 19's on and the standard steel spare. the rolling radius is near enough the same when you take into account the tyre profile. obviously the width is differnet, but it will get me home! (also have tyre weld just in case)
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    Jun 2003
    World of my own
    9,813
    The difference in the rolling radius is less than 1% if you have the correct profile/size fitted to 18" alloys. The only real concern is to ensure you carry a set of the original wheel bolts as my new ones were way too long on the stock spare
    Alex Turner
    hiltoa's Avatar
    VAG erfahren
    Jul 2006
    on the edge
    299
    ... and make sure you have the right type of bolts for your spare. My Golf now has BBS RY that take conical seated bolts wheras the OEM spare BBS RA needs Radius bolts.
    Luckily there's space in the McGuard packaging to keep the appropriate bolts
    Ebony Black.
    Tornado rot.
    Biglockie's Avatar
    Aye you know it makes sense
    Nov 2006
    cumbria
    1,030
    Standard 15" wheel in the boot but 19" rs6 rims, its only to get home
