Sky InsuranceVolks Autos
Results 1 to 12 of 12
Thread: Water leak
    951
    951's Avatar
    Feb 2007
    North east
    493
    Water leak
    The carpet under the passenger seat/rear foot well is getting wet,ive had the hose pipe on the car and couldnt see any leaks. any idea's where its comming from ??
    A4 Avant 1.8T Sport (183 bhp).
    simonwjones's Avatar
    Aug 2005
    staffs uk
    351
    have you checked under the windscreen scuttle pan for blocked leaves in the drain holes,also under the battery as well
    These can cause water to enter behind the glovebox and then under tye carpet to the back
    Simon
    A6 3.0TDI Quattro Avant Le Mans
    A6 2.5tdi Quattro Sport 180 Sadly Missed
    A6 1.9tdi Avant ................. Gladly missed
    A6 2.8 Quattro .................. Sadly missed
    Quattro 2.8 Coupe ............. Sadly missed
    SatNav, BT, AMI, DAB
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    Also check the seal around the pollen filter.
    A4 1.8T Quattro
    Feb 2008
    north lanarkshire
    I had the same prob on my 2000 s4 b5. It was a crappy push fit connection for the rear wash wipe located behind fuses in the front passenger kick panel. Re-connected it and taped it up with duct tape and its been fine. Hope this solves your problem.
    951
    951's Avatar
    Feb 2007
    North east
    493
    Thanks for the replys everyone,i will have a look tomorrow,strange thing is though the carpet in the front footwell is dry its only under the seat and rear footwell that gets wet !!!
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    it runs in though the airvents that are down under the passenger seat too
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Quote Originally Posted by 951
    If thats the case then its definately coming in through the ventilation system, probably leaves stuck around the filter intake.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Jun 2003
    World of my own
    9,813
    Also depends how far you've gone checking out how wet the carpets are. If all you've done is check them from the top, then the water collects at the back, once you lift the carpets you may find the front is wet as well, just not as much. There is an inch or so of foam under the carpet which wicks the water to the lowest point. Right PITA as you have to squeeze all the foam out to get it dry. Why Audi didn't feel the need to seal the foam so it wouldn't absorb anything god only knows. I bailed out over 5 litres when my drain holes got blocked and the carpet was only slightly wet in the rear on the carpet side.
    Alex Turner
    951
    951's Avatar
    Feb 2007
    North east
    493
    Eventually found the cause of the water leak,it was the return valve for the rear washer jet that had snapped and was just jetting straight into the passenger foot well (front and rear)which is about 3" deep in water !!!. Seems a stupid design to have the water pipe running straight though an electrics junction box to me as well !!!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    that is unusual, my 1996 model has the rear washer bottle in the side panel of the load bay would seem a bit of a backwards step if they've moved it from there!
    Jun 2003
    World of my own
    9,813
    Think they are all now supplied via the single washer bottle in the engine bay.
    Alex Turner
    951
    951's Avatar
    Feb 2007
    North east
    493
    Yes its supplied from the front bottle,i made a bit of a mistake though as the valve which had snapped was actually for the central locking which i only found out in the dark when the car alarm wouldnt set and the door would'nt lock. The water pipe had come off still and is just to the front of the electical juncton box ,fortunatly just a push fit so all done apart from i have a swimming pool in the front of the car which i dont think was an optional extra on the sports models !!
