Chris NottMonster Motorsport
Results 1 to 9 of 9
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    How much lower ???
    I have a 1996 A4 1.8t
    and have a set of coilovers I am going to fit, I will be running them with 19 inch rims with 235 35 19 tyres.
    My question is ....
    can anyone suggest how much to lower it so I still have a useable day to day car but get the improved looks/handling
    cheers guys
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    I'm running 19s with the same tyres and coilovers too, I lowered it from standard ride height, this:
    To this on coilovers, I couldn't tell tou how much exactly, just kept winding till it looked right, but you get an idea from the arch gap. Did roll the front arch lips slightly but have no major issues at all, takes 4 adults no problem.
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    you say adults but i'm only small!
    my A4 was lower than his S4 but had smaller wheels
    S3 - Gone but not forgotten!
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Stapo, how stiff are your coilovers?
    I've got really bad rubbing on my S4 with koni coilovers and H&R arbs set to stiff. Mine's not even as low as yours. I'm going to roll the arches, but i'm sure the tyres are rubbing on the inner arch.
    Mo power, mo problems
    stapo69's Avatar
    Mar 2007
    966
    To be honest the fk's aren't much stiffer than standard i.m.o. Maybe your offset is different placing your wheels further out in the arch? Different tyres maybe?
    And yes Si, I meen adults in the loosest sense of the word! And your wheels aren't the only thing of yours smaller than mine!
    Biglockie's Avatar
    Aye you know it makes sense
    Nov 2006
    cumbria
    1,030
    I had mine dropped right down and the front arches kept catching, had to raise it slightly. same size tyres and wheels on mine.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    i am on a tight budget so have jamex ones. anyone tried these how easy are they to adjust once fitted
    stapo69's Avatar
    Mar 2007
    966
    jamex/vmaxx is what sitrials had fitted on his A4 pictured above. As easy to adjust as any other coilovers really, take the weight off, get the spanner on em, watch your knuckles, and then sit for hours winding, measuring, winding, measuring.........
    diesel-a4's Avatar
    Stoned As Fuk
    162
    Quote Originally Posted by Biglockie
    thats the same for me. i had no other choice but to raise her, front bumper almost fell off. i dont know how the guy even got anywere with her running like that.
    shes far better now set at 2.5inches from the bottom of coil threads upwards. runs smooth
