Monster MotorsportVolks Autos
Thread: Oil cooler?
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    Oil cooler?
    Does anyone have any tips on changing the oil cooler on an 1.8T sport.. seems fairly simple but any information would be greatly received ie. gaskets required, anything to watch out for? etc.
    Cheers.
    Hampshire
    102
    Do you mean a stock replacement or fitting a take off plate and a bar and plate
    cooler?
    MY2000 Audi S4
    Ebony Pearl
    CXRacing FMIC
    RS4 Downpipes
    RS4 brakes
    Miltek Dual
    Vogtland CO
    K04's
    Lowered CR & MRC Magic......
    (RS4 ICs 4 sale - check classifed)
    macca's Avatar
    Sep 2006
    Sussex.
    525
    you only need to take the square part off i think, the bracket can stay on the engine.
    you undo the oil filter then there is a nut you need to undo to get the threaded tube out that the oil filter screws to.
    there is a seal i believe once you take the cooler off that goes between bracket and cooler. mine leaks here so suggest replacing.
    can't remember if the temp and pressure sensors go into bracket or cooler (think it's the bracket). but if you need to take them off then you need new crush washers.
    that's all i can remember from memory.
    1998 A4 1.8T Sport - For Saturdays
    2003 VW Golf MKIV R32 - For Sundays
    2000 Peugeot 406 HDi - For when it's raining
    1996 Kawasaki ZX7R - For when I'm late for work!
    Mods- Forge Dump Valve, The Engine Shop Power Plus based Engine (Low Comp. Forged pistons, Arrow H-Section Rods, Newman fast road cams, polished & ported head), 19" wheels, B&M Short Shifter, Greddy Turbo Timer, RS4 Grill, Weitec GTN coilovers, HKS modified air filter, Autobahn88 FMIC, ChippedUK custom map. Some Turbo mods ongoing.
