Volks AutosSky Insurance
Results 1 to 20 of 20
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    Water pump not belt driven on 1.8TQS
    Just got my car back from having the cambelt replaced. The guy said he didnt replace the waterpump as its the older style engine and not cambelt driven, he shown me the diagrams on the computer so that was fine and obviously didnt charge me for the pump.
    Thing is though he said its a seperate job with 3 hours labour at 150
    I am not spending any more money on this car!! In three months of ownership I have spent 665 on a major service, cambelt kit, ARB bush, brake fluid and MOT.
    My mate who is an engineer said leave it, if it fails it will leak first, thing is though I had a Renault Megan and the pump failed and the engine overheated and warped the head and the head gasket went.
    I know this isnt a Renault but I was wondering what mileage the pump on these should be replaced? Mine is on 56K miles on a W plate
    Skint because of my car, the forums made me do it
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,919
    With the water pumps they typically fail on the plastic impellor so the spindle spins inside it so the water isn't pumped round the engine. Had it happen on my old A4 on Christmas eve
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    What mileage was it on?
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,919
    130k of which 30k were mine and were hard miles
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    Ok thanks for the info, think ill leave it till the next service next January as I dont do that much in the way of mileage, probably less than 10K a year
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    I dont know of a 1.8T thats water pump is not driven by the motion of the cam belt etc
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    My engine code is AJL, I saw it all on the software, it looked to me that all 96 - 2001 1.8t's are like this but not sure
    Sep 2007
    33
    my water pump is also external, 1.8t aeb 1998. replaced it on 126000 cos the bearings were noisy - impeller was still perfect. it is easy to replace them yourself but space is tight.
    Space Invaders Champion
    Aug 2006
    65
    It's the V6 that has the cambelt driven water pump.
    The 1.8T is driven by the auxilary belt. I changed mine about 2 months ago, at 90,000 miles, and the impellar was about 45% perished.
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,698
    I replaced mine when did the belts. Was a bit of a bugger. It was definately driven off a belt.
    My engine code is AJL also.
    A4 1.8T Quattro, FMIC, Coilovers, B&M short shift, 312mm Brakes, Stage 4 clutch, Awe Gauge, Uprated antiroll bars, plus more bits. Pics Here
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    Quote Originally Posted by Soupie69uk
    Driven off an auxilary belt and not the cambelt?
    What worries me now is what this other belt is and how long is it supposed to last!? The mechanic new that he could of got another 150 out of me but he told me not to worry about it, cars suck
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    The point of doing the waterpump the same time as the timing belt is that there is very little extra labour required. It is also worth changing the auxilary belt (and air conditioning belt if you have it) as well. In addition to this it is worth changing to the newer style tensioner.
    On the bright side, the failure of the waterpump will not cause your cambelt to snap and destroy your engine. The downside is that you will in the near future have to spend another 200 having the waterpump replaced.
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    The mechanic said it was a seperate job, I also found this strange though. The cambelt and tensioner was replaced
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    As above its normally all the same job, i would have told the mechanic "look i asked you to change it do it please" as it sounds like he talked you out of doing it possibly becuase he could not be arsed.
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/showthread.php?t=43296
    Sep 2003
    medway,kent uk
    103
    my water pump went at 115 k on my old w 1.8t when it overheated
    stevie
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    115K, thanks, everyone who has commented on failure has mentioned over 100K miles
    What confuses me is that I have never seen a mechanic turn down business before! He literally said not to worry about it and didnt recomend booking it in to get it done. He also discounted the total cost accordingly.
    Going on the low mileage of the car and the mileage that I do per year, it can wait till the next service and I am not going to worry about it.
    Dec 2007
    Brighton - well Hove actually
    71
    Quote Originally Posted by johnie72
    Gulp..
    2.8 30V V6 193PS
    Gone. But not forgotten
    Now
    A4 2.5tdi 180 quatro
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    Spoke to Audi today, 80K miles is the recomended on the AJL engine for a waterpump change
    macca's Avatar
    Sep 2006
    Sussex.
    525
    did mine at 85k, belt driven AEB 1998 engine, same on a 1999 APU engine. got a non audi one from eurocar parts for about £25 and had metal impellers.
    1998 A4 1.8T Sport - For Saturdays
    2003 VW Golf MKIV R32 - For Sundays
    2000 Peugeot 406 HDi - For when it's raining
    1996 Kawasaki ZX7R - For when I'm late for work!
    Mods- Forge Dump Valve, The Engine Shop Power Plus based Engine (Low Comp. Forged pistons, Arrow H-Section Rods, Newman fast road cams, polished & ported head), 19" wheels, B&M Short Shifter, Greddy Turbo Timer, RS4 Grill, Weitec GTN coilovers, HKS modified air filter, Autobahn88 FMIC, ChippedUK custom map. Some Turbo mods ongoing.
    Jan 2006
    Deal, Kent
    468
    Had mine done, 2000 AWT engine, at the same time as cambelt / kit, genuine parts through the Skoda dealer who did the job, only 33 for the pump. They said it is in "with the cambelt" so unsure if driven by it or the aux belt, but it is a lot of labour later on, including removing the cambelt (which will have to be replaced) to get at the water pump later.
    I hate it when they talk you out of preventative maintenance cause they are the ones with dirty hands. If I ask for something to be done and I am paying, I bloody well want it done!
    2001 VW Passat 130 TDi Sport 6 Speed
    1999 Honda CBR900RR-X FIREBLADE
