EM TuningJMB Retrofits
Results 1 to 7 of 7
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    Rear Arm Bushes...
    Hi folks,
    Just wondering if anyone can advise...
    I've just had the car back from MOT and while it took a bit of maintenance/repair work to get through it did...
    Overall the car's doing well, in a smidge under a year it's done over 60,000 miles so naturally some wear and tear items have needed replacing.
    It's just had front discs and pads, and near-side CV boot.
    Shortly before Christmas it had cambelt (kit), water pump, rear pads and all eight arms at the front.
    It's come back from MOT with a couple of advisories...
    Firstly - the off-side CV boot is probably going to need doing soon (why they didn't do it at the same time is beyond me), but that's straightforward enough...
    The other is that the rear lower suspension bushes are worn, not dead yet, but will need to be done soon...
    My question then is this...
    Is this a job I can tackle myself easily enough, and do I need completely new arms, or can I just get bushes from somewhere?
    Thanks in advance...
    Rob
    The truth they're trying to keep from you is that IPv6 has nothing to do with address space; we're actually running out of full stops.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    You can get the bushes on their own. I've never done the job myself, but i've seen some write-ups which suggest that it's doable if you have the patience.
    Apparently the old bushes can be a bugger to get out.
    To give you an idea on price, I've just had four bushes replaced on my rear arms on my S4 and the parts came to £45 (inc.VAT).
    Mo power, mo problems
    joost's Avatar
    Nov 2005
    Lancs
    1,166
    Is yours Quattro Rob?
    Justin
    2001 VW Golf 2.3 V5 (170) Highline, Indigo Blue - standard, for now...
    A4 (B5) SE with a few slight amendments here and there (sold)
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    Ordinarily I'd be unhappy to say it's not Quattro, but I guess in the case it'll make life easier. It's FWD...
    Regards,
    Rob
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    Thats an 5/10 DIY job then, just make sure the new ones are facing the right way and you are golden
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    Cheers guys!
    I'll track down some bushes and have a crack next week then!
    I 'd been wondering if there was something getting worn at the back as with big bumps I've noticed the odd knock - couldn't make my mind up if it was that or the big socket set I have in the boot!
    Regards,
    Rob
    Apr 2004
    12,521
    Iirc i cut my old ones out and pushed my new ones back in with some exhaust pipe and some stud bar to pull it in. I think they were arounf £20 a side
