Name That Bumper!?
SmoothAssault
Will design for mods
Cambridgeshire
Website
www.matteasom.com
So as while I was looking around online for an OEM RS4 front bumper, I found this beauty, but there was no information about it...
Can you 'name that bumper'? It looks like it's from the states (wheel on wrong side, no front plate) but I'm hoping it might be a available in the UK.
Thanks :icon_thumright:
Definitely American-spec. It's got the side marker at the front.
Not bad, if it's made of ABS plastic.Would prefer it though, if the lower ducts were the single type, double layer makes it look rather busy and cluttered.
I know your after the RS4 look bumper and your intrested in my old one but Siena as first offer at the moa but may be you should be looking sothing mor OEM rather than these fiberglas stuff.
May be this will fit the bill.
And there are write-ups on how to do this plus it's all OEM.
Yes, I would much prefer something OEM like that. Surely Audi dealers don't have any knocking around any more though do they? Plus I don't really trust the dealerships near me, they've tried to screw me more than just a couple of times.
Where's a good place to get hold of the OEM parts?
I would use three RS4 centre grills and plastic weld them in place plus you could still use your original spots by plastic welding them in place.
Tools and products used:
X-acto knife w/various blades, fine toothed saw, drill, sheet metal cutters, sand paper of various grades, sanding block, two-part liquid epoxy, two-part clay epoxy, rasp, files, cable ties, primer, spot putty, metal mesh
Bumper parts
8D0-807-103J GRU
S4 FRONT BUMPER $383.95
8D0-807-977 GRU Lic plate trim $50.50
8D0-807-345-L-GRU
Left Grill $20.30
8D0-807-346-L-GRU
Right Grill $20.30
Start with one of the side grilles . This way if you mess one up it will be cheaper than the bumper to replace.
Look at the back side of the grille and see where the black grille insert is held on by melted tabs. Remove these tabs by cutting or grinding them off. Remove insert from grille.
Cut center bar from the grille frame. Make sure you cut close enough to eliminate the flaired contours where they meet the edges. Take the center bar you just removed and cut a slat that will be big enough to cover the holes you just made in the frame.
Rough up the slats you just made and the backside of the frame on each side of the holes you made.
Use the liguid two part epoxy to attach the slats to the frame. This will give you back some of the rigidty you lost when you removed the center bar. Set them aside for 24hrs.
After they above has cured ,take some of the two-part clay epoxy and fill the holes on the frame. Makes sure you have enough epoxy so that it is a little higher/thicker than the surrounding frame. Also wrap some of it around the backside over the slat you epoxied on earlier. Let it cure for it least the time specified on the package. Once the above has cured use a rasp to remove the bulk of the epoxy to get it close to the shape of the frame your are trying to match. Finish with finer toothed files and sand paper until you have matched the frames contours.
Prime the area and let it dry. Check to see if any areas need to be addressed. High areas can be sanded more, low areas can be filled with more epoxy, once the area is sanded free of primer, and the above step repeated.
Small pin holes can be filled with spot putty and left to dry and resanded again. Prime and recheck and repeat any of the above steps until the desired results are achieved.
Set aside until dry.
Take the frame and the mesh of choice. Lay the mesh on the backside of the grille and trace the outline of the grille onto the mesh and cut out. Give yourself some extra, which will be cut down later.
Take some of the center bar removed at the beginning and cut sections off that resemble the letter "J" .
You will epoxy these to the outer edge of the frame on the backside to use as attachment points for the mesh. Lay the mesh on the backside of the grille frame and line up as desired. Mark places on the frame that would line up with the mesh and could be used as attachment sites (make sure these site will not interfere with the grilles mounting tabs). Trim the "J's" you made earlier until they are shorter than the height of the grille edge. Also remove some of the material from the "J" until it looks like an "L".
Take the "L's" , roughen the attachment points, and epoxy them to the pre-chosen areas with the liquid two-part epoxy. Let it cure for 24hrs.
Drill a hole into each of the "L's" large enough for a small cable tie to pass through. Lay mesh on grille frame and attach with cable ties. Mark excess areas of the mesh to be cut off. Remove cable ties. Cut off excess mesh.
Repeat the above for the remaining grille and bumper.
Once done, remove cable ties, dress the cut edges of the mesh with a file until they are no longer sharp. Paint or powder coat mesh. Install once everything else has been painted.
Done
Painted parts.
Finished product.
With thanks going to Katana for answering some questions.
That's a goog tutorial I spotted it on AudiDIY the other day I think.
I'm going to have a look at the S4 bumpers, I might be just as happy with one of those and have 10000% less work to do.
Thanks =]
