Chris NottSky Insurance
Results 1 to 9 of 9
    97_A4_1.8Turbo's Avatar
    Oct 2007
    Chicago USA
    50
    Exclamation code poping up on the odometer
    there is a code that is poping up on the odometer its "ln l" its coming up right umnder the millage of the car when i start it up it flashes for a while.
    does any one know wat the code means?
    1997 audi a4 1.8T fwd
    mods:
    custom intake, testpipe,Exhaust, turboXS manualboostcontroler,brembo rotors
    future mods:
    frontmount intercooler, rieger rs4 style body kit, dual angel eye projector headlights, smoke tail lights
    Road Razor's Avatar
    Tyne & Wear
    390
    Cars without DIS will show In 1 or In 2. In 1 = Inspection 1. Your car is due for a service.
    A4 2.4 V6 2000.
    Oct 2005
    lebanon
    92
    and what is dis , and cars with dis showes what
    RGBArgee
    Quote Originally Posted by kninio
    DIS is dat thing called a 'Drivers Information System' and in this case DIS shows you dat a service 1 is needed.
    Milton Keynes UK
    248
    Hi,
    Below is copy of the instructions on how to reset the inspection service light from a post in the Diesel section. It might be worth a try!
    Press and hold the right button. (odometer reset)
    now switch on the ignition
    (oil lamp will not flash, but on at all times)
    press the right button again
    (insp is now displayed)
    pull left button. (clock set)
    (------ are now displayed)
    Pull left button again
    You might have to try this a few times to reset everything (oil & in1).
    This works on my A4 tdi (110bhp) but should work on all.
    Jim.
    Oct 2007
    2,597
    Original poster's car is fairly early, so manual re-set MAY not work.
    Manual re-set became European legislation from about '98 - i.e ALL cars manufactured after this date had to allow the owners to re-set the service interval without special equipment, in this case, diagnostic equipment.
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    there is a write up on www.ross-tech.com
    TopGear Stockport / Longlife Exhausts /
    www.TopGearStockport.co.uk
    Oct 2004
    41
    in 2
    Hi does anyone know what In 2 means on the odometer?
    thanks
    Jonathon
    Milton Keynes UK
    248
    Inspection 2 Service required.
    I assume your service book should advise what is required.
