Chris NottMonster Motorsport
Results 1 to 11 of 11
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,742
    Porsche calipers.
    Hi folks just a few questions.
    I know the Boxter calipers fit on the 312mm upgrade discs and the Boxter s and 996 carrera calipers fit on the S4 disks.
    But which ones fit on the 322x32mmdiscs?
    The 996 turbo or the GT3 4 pots?
    What size discs do the cayenne turbo 6 pot calipers need? Can they be used with a smaller disc than say 345mm?
    I ideally would like to still be able to run my 17s even if spacers are needed.
    A4 1.8T Quattro
    Feb 2007
    144
    Out of interest could boxster calipers and 312 discs be swapped onto my b5 tdi as I got the 288mm vented fronts.
    Or do I need moddified carriers?
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,742
    Yeah you would need carriers and new brake lines
    A4 1.8T Quattro
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,742
    Just to add I have found a company which sells blank bells, carriers and universal discs.
    How would I work out the size of the offest for the bells?
    Then I think it would just be a case of getting them drilled for 5x112 and getting the carriers machined.
    A4 1.8T Quattro
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Who are they as i need some carriers for my new brakes.
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,742
    Sorry I forgot to put the link!
    http://www.rallydesign.co.uk/catalog...&filter_id=579
    Looking again at these I think they are universal for willwood brakes only the carriers but the bells etc should work.
    What calipers you got?
    A4 1.8T Quattro
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Its possible you might get them if you ask the dimensions as they do say universal.
    I hope to have a set of Movit calipers soon i really rate them more so than some of the others avaliable.
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/showthread.php?t=43296
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,742
    Yeah are they not the same as the brembo porsche ones? Should be great.
    What size discs you going to get?
    A4 1.8T Quattro
    jcb
    Sep 2005
    uk
    4,077
    Quote Originally Posted by Soupie69uk
    buy the time you have bought bells and discs for those you look to be spending 3-400 for discs the smaller than B5/B7 RS4 discs at a lower price. before you have bought fittings and drilled stud patterns into the bells and adapters
    looks expensive. how big are you going?
    this is B5 RS4 (360mm) with Cayenne 4 pot rears on an S4 hub. lots of room for an adapter
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,742
    I think the disc size I want is 323mm x 32mm. As I want to be able to keep 17s.
    I was reading on one page that the 6 pot cayenne calipers can use discs between 322mm - 360mm. What you reckon? Would say a 323mm disc hardly go in the caliper?
    I also notice those are the cayenne 4 pot rears above. Have you got the part number? They may be the same as say the boxter s fronts or the older 4 pot GT3 calipers.
    A4 1.8T Quattro
    Feb 2007
    144
    What is the most simple change and upgrade on discs say I wanted to go upto 312mm.
    I understand the carrriers, new lines needed for the extra fluid 4pots require?
    And if going 312mm upfront, would I need to uprate the rears also for balance as 2/3 or the braking effect (or something like that) comes from the fronts anyway.
