AH FabricationsChris Nott
Results 1 to 10 of 10
    97_A4_1.8Turbo's Avatar
    Oct 2007
    Chicago USA
    50
    i might have a turbo problem?i need some help
    i have notice a while ago that after i drive for a while it seems that my turbo heats up and slightly glow red in the section where it connects to the catconverter.
    does any one know wat the problem is???
    1997 audi a4 1.8T fwd
    mods:
    custom intake, testpipe,Exhaust, turboXS manualboostcontroler,brembo rotors
    future mods:
    frontmount intercooler, rieger rs4 style body kit, dual angel eye projector headlights, smoke tail lights
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    If its glowing under normal driving, the cat is probably blocked. Either rip it out and chuck in a test pie, or replace,depending what you smog laws are there
    jcb
    Sep 2005
    uk
    4,070
    vag com and check your timing and A/F ratios.
    if you cat was blocked it would effect others things as well.
    does it drive OK?
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    Is your fuel pump up to the job? If not, you might be running higher than normal EGT's.
    Mo power, mo problems
    Oct 2007
    Chicago USA
    50
    Quote Originally Posted by jcb
    does it drive OK?
    it drive ok but its not putting out a lot of boost its like 3-4psi lower than it use to be
    mods:
    future mods:
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    ive got the EXACT same problem!! i cant say if i lost or losing power because ive just replaced loads of pipes and clips and a new 710n bov. so im at the mo runing at 8-9psi and my turbo glows slightly it also smells of hot metal in the car. and when i increase the psi on manual boost controller the twhole tubo glowed red and the thuds at 3k revs and judders and wont let me past 3k!!!!!
    Modified primera :-)
    mac1403's Avatar
    Sep 2005
    wales uk
    956
    Quote Originally Posted by Byzan A4
    A test pie? LOL......just pictured someone trying to work out where to put it!
    Facelift S3, Sprint Blue, Bucket seats, Sunroof, Sat Nav, Bose, Elect Mirrors, Light and Rain, Interior Light pack, Flat Tyre Warning, GSM Phone Prep, Led upgrade, Illuminated speaker grills.
    Apr 2004
    12,355
    Quote Originally Posted by mac1403
    American for cat bypass pipe
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,824
    did some looking else where and it prob is the CAT blocked and you may need a new DV why your at it, take the O2 sensor out and see if the boost goes up.
    Oct 2007
    Chicago USA
    50
    how do i make it so that the check engine light wont go on faulting low pressure in the cat?
    becuse i put a testpipe in (decated it)
    mods:
    future mods:
