Results 1 to 18 of 18
    Feb 2007
    144
    Head gasket went pop again! Oil cooler?
    OK the saga continues I got the car back and could tell something was up and then on the 3rd day of use at just about 200 miles it went pop again.
    Need another head gasket done!
    The garage have had a look and said it was prolly the oil cooler gone that made the headd gasket go.
    I need some advise here, on firstly does this sound right to you guys as I have never heard of oil cooler failure. And thus linkage to the head gasket.
    But also I put the car in to get the head sorted as was the suspected problem and it did need doing. But is this the garages fault for missing the oil cooler and the head going pop again?
    Just need a leg to stand on as I don't want to pay for the head beinig done twice.
    Oct 2007
    2,597
    The only link between the oil cooler and head gasket, is both would allow oil and water to mix.
    A leaking oil cooler would NOT cause head gasket failure, UNLESS it was corroded and holed externally, causing a loss of coolant, followed by overheating. But, they tend to leak INTERNALLY.
    Oil cooler failure is not that uncommon.
    Find out what head gasket was used, was the head checked for trueness, and was it skimmed? Were new head bolts used?
    Finally, what model of car do you have? I'm stabbing in the dark here, you've probably mentioned what car you have in the past, but I couldn't remember what everyone drives...
    ...A bit more info would be great.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    I had the same diagnostics on a golf tdi turned out it was the oil cooler but the head gasket was infact fine just some garage who jumped to conclusions oil in water = headgasket blown . The oil in the coolant system may have stressed the head gasket hope it all works out
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Feb 2007
    144
    I have a moddified afn tdi engine. Remapped and .215 nozzles.
    I see what you are saying siena.
    Hopefully there will be no reskimming, they did use new stetch bolts and the garage untill now has always been spot on.
    What happened was the oil all ran into the expansion tank and I was getting dark smoke.
    Not sure on parts used for part no's and make.
    jcb
    Sep 2005
    uk
    4,077
    head gaskets don't just go, something causes them to go.
    whoever did the last one didn't find the cause before rectifying the symptom.
    oil coolers often go, especially in older cars
    until someone does a full wet and dry compression test then you won't know.
    personally I would be wary of anyone who say "the oil cooler made the gasket go".....
    Jpc
    Mar 2007
    124
    The cooler going causes the oil and water to mix, it can look like the head gasket is leaking into the oil line.
    Feb 2007
    144
    where would you guys stand if he tries to charge me again on the head gasket?
    Oct 2007
    2,597
    To be honest, I don't think you can hold the garage liable.
    They can only reasonably check the direct cause of gasket failure, i.e if the thermostat was stuck shut, the fan wasn't switching on when it should, the header tank / radiator / hoses had leaks, all of which would cause overheating, leading to head gasket failure.
    They're unlikely to check the internal condition of the oil cooler (unless it's removed and pressure tested), same way as they're unlikely to check the general health of the rest of the engine. That would be a major inspection, and would considerably add to the final bill.
    The only way I feel you could challenge them, would be if you could prove they used sub-standard parts, i.e a non-OE headgasket, or re-used the original headbolts. These things happen, it's just unfortunate the headgasket failed so soon after it was replaced.
    Feb 2007
    144
    Yea, I think the guy might let me off some charges but I will see.
    He has this time sent the oil cooler off for pressure testing.
    I just hope to get the car back soon in tip top condition as the 1.9 d megane is driving me nuts.
    This has really helped me add to my determination to learn everything about these engines, now to lay my hand on idiot proof literature about diesel engines and how they work in their entirety.
    Jpc
    Mar 2007
    124
    did you not notice it overheating?
    Shifty's Avatar
    Avvve it!
    Oct 2007
    wales
    47
    Was it the oil cooler or oil pump? u coulda fried the head if it lost oil pressure?
    Oct 2007
    2,597
    Quote Originally Posted by Shifty
    Oil cooler.
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    Makes you wonder if it was the oil cooler leaking all along. Did you ask if there was any sign that the gasket had failed ?.
    I would change the oil cooler anyway, they are about 60ish I think, worth it for peace of mind.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Head gasket going again after leaving the garage 3days i would leave the bill in there hands as they must of looked to see what caused the head gasket to go in the first place ..Its not your fault it went again its theres for not checking the fault that was there previously
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    Feb 2007
    144
    Confirmed today it was the oil cooler that went! damned thing.
    At least the engine is ok thou.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,500
    So the head is fine, but the cooler is US ? Does that mean that they didnt rip it apart again then?
    Oct 2008
    sorry i come along so late .. i found this google-ing for rs4 headgasket thickness (compared to s4-s) ..anyway
    i have/had the problem with coolant in oil in my 01 Hbox B5 S4 .. it is nothing but porosity or small crack in the block !! i had my engine apart thinking it was the head gaskets ..but nope it was not .
    i was at AUTOSPEED in NJ when we found the porosity in someone's block that had the problem , die in coolant was used , presurized the system then oil pan dropped as the black light pointed to our origin , the a boroscope was used up where the coolant was coming from (dripping down the oil return gallery from head to block ) 1/2 way down the block - NOT near the hadgasket there were coolant bubbles coming up like sweat on the wall of the block and dripping down into the oil.
    i'm still runing my block like that for a few years now as stg3 ASP (near 500HP) and i used BAR's LEAK into the coolant to almost stop the leak .. it worked so far , now i'm building another block to replace mine (all new pistons, rods - bored to 2.8 L - 82.5mm bores...)
    search audiworld for my posts on this topic .
    don't waste $ trying to fix this before you properly dignose the problem !!!!
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,071
    Sounds like what happened to my first A4. Garage diagnosed fault as being headgasket so the ehad came off. 2 days later the mayonaise was back. It was the oil cooler all along. They are seperate and can not cause each other to fail.
    Sounds to me like they midiagnosed the problem and are now wriggling.
    Life begins at 140mph
    www.passionford.com
