Volks AutosChris Nott
Results 1 to 9 of 9
Thread: DIS
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    DIS
    May be a stupid question but i have tried to search for an answer, is it possible to put DIS into a car that does not have it i know the clocks need to be programmed etc because of the imobiliser but would it work ?
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    Anything is possible, but i believe the intergration to be a lot on the dis sytem,so you would need all sorts of sensors,wiring and control units,as well as the dash and skc etc
    macattax's Avatar
    Oct 2006
    Ireland
    451
    Wouldnt even atempt it m8 unless you are an eletrical engineer and have a good working knowledge of low level computer languages 101010101000111011010111 etc.
    FACELIFT 99.5
    Current Mods: RNS-E MMI Conversion,Carbonio CAI,
    Baileys DV30 valve, Tinted windows, Xenon H.I.Ds, Bosch Aerotwins.
    Planned mods: Rieger Kit,Engine Tuning, Leather sports seats.
    Accomodation when the missus kicks me out for wasting money on a car.
    Oct 2007
    2,597
    Very possible.
    Early cars won't need the cluster coding either.
    macattax's Avatar
    Oct 2006
    Ireland
    451
    bollix
    FACELIFT 99.5
    Oct 2007
    2,597
    Quote Originally Posted by macattax
    bollix
    No worries, it's cool, no shaking.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Quote Originally Posted by Siena
    Very possible.
    Please explain as i am all of the above
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/showthread.php?t=43296
    Oct 2007
    2,597
    Early cars with the IMMO controlled by the "black box" under the steering column won't need the cluster coded to the ECU / key.
    Wiring isn't too bad either, if you know what you're doing.
    macattax's Avatar
    Oct 2006
    Ireland
    451
    Well if you decide to do this I wish you the best of luck. But I can only imagine that the wiring of this is going to be quite complicated.
    Sorry Siena but have you actually done this or have seen a guidde on doing it?
    If so could you post up some more details as I would be very intrested in seeing how everything connects up as it may solve a problem some of us have here with DIS not showing doors are open.
    Also include the schematics to which relays are connected to the DIS if you can.
    Not a job I would untertake myself as if there is no wiring in place for a DIS then I would imagine the cars ecu wont recogise it without adding some sort of coding to the Ecu.
    Hopefully Sienna will come up with the goods for you Markey and then you can decide wheter to do it or not.
    FACELIFT 99.5
