JMB RetrofitsVolks Autos
Results 1 to 14 of 14
    Mar 2004
    15
    a4 starting problems
    hi all
    at last i seem to have found somewhere that may be able to help with my fault as audi dont seem to have a clue.
    i have had random starting problems for the last couple of months on my 2000 t sport .the car somtimes refuses to start on the first turn of the key and will then spluter into life on the second or third turn.
    i have also got a temp gauge fault at the moment where the temp gauge will rise and fall between cold and halfway as if the sensor is breaking down .
    could it be that these problems are related and the ecu thinks the engine is colder than it actually is and operates the coldstart valve.?????????
    this is driving me mad as well as being slightly embarsing when im winding the starter over and over on a car that should start on the button.
    hope someone can help
    dazza
    Mar 2004
    15
    Re: a4 starting problems
    thanks for the help .i will try changing that first [img]/ubbthreads/images/graemlins/groovy.gif[/img]
    Mar 2004
    15
    yeah ..had audi check for faults at the last service but they came up with nothing.
    seems to have got worse since then though.
    i dread starting it now i case it gives up alltogether,not what you want from a four year old car.
    Mar 2004
    15
    dont know if this is the same problem ,mine doesn't start then cut out with a flashing imoboliser it just wont start and when it does it stinks of fuel ,its also a late facelift model.
    i will take the coulum shroud off tomorrow and take a look .what excactly am i looking for??????
    May 2003
    UK
    45
    I'd definitely change the coolant temp sensor. It is a known problem on the 1.8T engines and only costs about 12 from German and Swedish. (The fact that the temp guage is playing up also points to this component)
    Andy
    Mar 2004
    15
    gonna go to german and swedish tomorrow ,so fingers crossed
    Mar 2004
    15
    still havent got round to changing the sensor and the fecking things got worse.its now spluttering and missing slighly when it starts ,im kinda hpoing it packs up alltogether so at least i can pinpoint the fault.
    Mar 2004
    15
    changed the coolant sensor on monday and its been good as gold all week .
    thanks to all those of you who posted.
    nice one [img]/ubbthreads/images/graemlins/groovy.gif[/img]
    Mar 2004
    15
    [ QUOTE ]
    Cyberdude said:
    Can anyone tell me where the coolant sensor is located.
    [/ QUOTE ]
    its at the back of the head in a plastic housing held in place by a little horse shoe shaped clip.should be black or blue in colour.
    Dec 2003
    31
    Thanks. I'll get one next week and see if it fixes my problem.
    Mar 2004
    I had a starting problem where the car would not start and the immobaoliser light would flash. Taking the key out of the ignition and reinserting would solve the problem. Audi told me it was the coil in the ignition which "talks" to the chip in the key that was faulty and that I should replace the ignition. I got another dealer to give a second opinion, they simply moved some wires around the ignition from close to the key to further back and fixed the problem at a fraction of the cost. I assume it must be noise which creates interference or something????
    Dec 2003
    31
    Hi can anyone give me a part number for the coolant sensor on a 1.8 NA engine. I just t be sure I am armed with it when I go to the dealer here in Portugal. 2000 model A4.
    Also, if anyone can paste a quick How-To for changing it the sensor that would be great. I assume it is fairly easy, but just want to be sure there is no unexpected surprises. Thanks.
    Lowride's Avatar
    Sep 2003
    Warwickshire
    133
    I don`t know if I hav the exact same problem as you guys but it is similar..
    Most of the time my A4 1.8i will start fine first time but then other times it will start and then cut out one second later. I find that if I giv it a good rev at the same time as turning the key I don`t get the problem but I shouldn`t hav to start it like this
    It does it when the engine is hot and cold, it makes no difference. I sent it into a local VW/Audi specialist called BRM in Leamington and it has been better but its slowly getting worse
    I work at Mercedes and had a chat with the master technician, he has a mate who works for Audi but not locally, his mate seemed to think it would be down to either:
    Throttle potential-ometer or the Temp sender
    Is the coolant sensor the same thing as the temp sender?
    I know nothin about engines, obviously!
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    No the coolant switch is different it feeds the ECU with what temp the engines running at and then allows the correct fuel to be added. If it is faulty or in most cases playing up it will try and run rich or lean. Basically it gives the info for your auto choke to open and close.
    I had the same prob with my 2.8 but it also affected the running of the car like jerking some times or just stalling when at a standstill and then not start. Since replacing mine its been ok. 20 from Audi and get the O" ring to go with it.
    All you need do is remove the clip fitted in the side by pulling it out remove coolant switch and old O" ring seal and reverse the process. 20min job tops.
