Volks AutosEM Tuning
Results 1 to 10 of 10
    robbie5's Avatar
    NEVER ENOUGH
    Nov 2007
    98
    Removing dial perspex...
    Q. How difficult is it to remove the clear perspex covering the Audi B5 dials? I've bought a set of silver rings to place around the dials and thought this might be the best thing to do...?
    Rob
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    This should help.
    First is stock....
    Take off top steering cover in the middle of the gauge cluster, remove the 2 torx screws , then unplug the three plugs behind the gauge cluster
    Remove the two torx screws behind the cluster and pry out the 9 tabs around it and separate the cluster
    Ahhhh the rings
    2 rings installed
    All rings installed
    Cluster back together
    Install in reverse order... plugging in the rear plugs was a PITA...
    Ohhhhhh careful not to scratch the Rolex presidential.....thank god..
    And the final pic
    All in all well worth it. Glued the rings down with clear silicone adhesive... turned out great.
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    I did this mod on my old Mk4 Golf.
    You don't actually remove the perspex from the pod. You remove the speedo console and undo half a dozen screws which split the front section from the clocks.
    You then have to install the rings from the back by gently squeezing the alluminium rings and passing them through the holes in the back of the front half of the binacle. You then need some gel superglue to attach the rings permanently. Just be very careful with the glue as any spills with ruin the effect .
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
    robbie5's Avatar
    NEVER ENOUGH
    Nov 2007
    98
    The seller of the dial rings said...they click into place (no need for glue) mmm we'll have to wait and see.
    Thanks guys, as per usual you're all...diamond geezers!, said in a Del Boy accent!
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Quote Originally Posted by robbie5
    Thats interesting im not sure where they would click, esp if you hit a big pot hole and they fall off
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    When i got mine they said they would click into place but they didn't lol. Theres not much for them to click into. Glue did the trick though.
    Built in Germany, Perfected in England
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    I have been looking for a set for my car which does not have DIS are they avaliable ?
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/showthread.php?t=43296
    robbie5's Avatar
    NEVER ENOUGH
    Nov 2007
    98
    DIS?
    S4 AVANT(325BHP & 370lb/ft)
    MRC remap > Miltek Cat Back > 19" split rims > RS4 grill > RS4 silver rails > Silver mirrors > Full Cream leather Recaros > B6 steering wheel > RS4 gear knob > Eibach springs > K&N filter
    RS4 (standard at the moment)
    Jan 2007
    Hampshire
    1,155
    DIS?
    Driver Information System (trip computer!)
    A6 3.0 TDI.
    robbie5's Avatar
    NEVER ENOUGH
    Nov 2007
    98
    Quote Originally Posted by Markey
    No, unfortunately not.
