AH FabricationsChris Nott
Thread: Clutch problem
    Oct 2005
    lebanon
    92
    Clutch problem
    Hello , i changed my clutch and pressure plate and pilote bearing , and now it vabrite a bit in accelaration , is that normal and goes with time? is that possible because of the flywheel? and will goes with time when the clutch take the shape of the flywheel? or any other issue can cose this?
    Space Invaders Champion
    Aug 2006
    65
    As far as I know you're supposed to changethe flywheel at the same time as changing the clutch. I'm sure some one will be along soon to correct me though.
    Oct 2005
    lebanon
    92
    as far as i know i must resurface it but i didnt i just sand blast it a bit , i think this vabrition when i took my foot from pedal is do to slip in the begin , cos it only when i engage the clutch , i think when the clutch will take the shape of the flywheel it will be 100% fine? or some one correct me please
