Chris NottSky Insurance
Results 1 to 24 of 24
Thread: help b5 brakes
    twostrokepower's Avatar
    Oct 2007
    131
    help b5 brakes
    hello guys
    will AUDI RS4 B5 CALIPERS,DISCS go straight on to my A4 2.8 quattro B5
    many thanks
    simon
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Go here and check the differences you might need to make up mouting brackets?
    http://www.vagcat.com/
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    macca's Avatar
    Sep 2006
    Sussex.
    525
    i don't think they do if i remember correctly. The s4/rs4 hub carriers are different.
    1998 A4 1.8T Sport - For Saturdays
    2003 VW Golf MKIV R32 - For Sundays
    2000 Peugeot 406 HDi - For when it's raining
    1996 Kawasaki ZX7R - For when I'm late for work!
    Mods- Forge Dump Valve, The Engine Shop Power Plus based Engine (Low Comp. Forged pistons, Arrow H-Section Rods, Newman fast road cams, polished & ported head), 19" wheels, B&M Short Shifter, Greddy Turbo Timer, RS4 Grill, Weitec GTN coilovers, HKS modified air filter, Autobahn88 FMIC, ChippedUK custom map. Some Turbo mods ongoing.
    Oct 2007
    131
    WOULD I BE ABLE TO CHANGE TO S4/RS4 HUB CARRIERS TO USE RS4 DISCS? BECAUSE MY 2.8 BRAKES ARE NOT UP TO THE JOB OF PULLING UP SUCH A HEAVY CAR , HAVE TRIED CROSS DRILLED DISCSA ND UPRATED PADS BUT FIND THE 280MM DISCS ARE JUST TO SMALL.
    THANKS
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,841
    Ok here what you can do Satans Child is selling S4 Hubs with new barrings you will just need to swap out the drive shafts as the S4's will not mate up with the Gear box flanges. then rou will be able to mate S4 or RS4 brakes and disc on that.
    Or do the TT carrier conversion with a set of A8 discs.
    Oct 2007
    131
    HAVE TRIED TO CONTACT SATANS CHILD 3-4 TIMES WITH NO REPLY I WANTED AND STILL DO B5 S4 SPEEDO CLOCKS HE HAD FOR SALE .
    THANKS
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    I thought the S4/ A4 had same PCD so the disks would fit the same ?
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,841
    Disc will mount not sure they would work with stock calipers with TT carriers.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Ok cool as i have the disks and some differnt calipers on the way just need to get some carriers made up or i was hoping that there were some out there that would fit
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/showthread.php?t=43296
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,841
    Quote Originally Posted by Markey
    You will be the pioneer on this one.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Dam it and there was me thinking that i could copy someone
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,841
    Or may be think along the S8 brembo route as a carrier looks to be quite easy for that.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Not sure i have the movit brakes coming and i really like their quality think there better than Brembo.
    I will see what i can do i may just sell the disks and get different ones with TT carriers.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,841
    Movit are good so stay with them, me on the other hand work to a budget and the budget needs to include servicing and that means pads.
    The B7 RS4 & RS6 Brembo pads cost 300 for a set which is a killer but for my B5 RS4 calipers I picked up a set of pads new for the front and rear for only 70 so this is a strong factor when upgrading although S8 Brembo's seem good with a 100 for a set of front pads.
    Oct 2007
    131
    OK IVE BEEN OFFERED 2 POT RS4 CAILPERS AND DISCS FOR £180 SO MAY JUST BUY AND SEE IF I CAN MAKE THEM WORK ON MY 2.8 QUATTRO ? WHAT DO YOU LOT THINK
    THANKS
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    2 POT i thought all RS4 brakes B5 shape were 4 pots.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,841
    Not the B5 RS4 they are just bigger version of the S4.
    Oct 2007
    2,597
    Quote Originally Posted by twostrokepower
    THANKS
    No. S4 clocks don't plug into pre-facelift cars, plugs and wiring harness are different.
    Oct 2007
    131
    thanks for info ,have been told they do , dam!
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,841
    Satan's clocks are not face lift but pre-face lift
    Oct 2007
    131
    so they will ,,,great
    thanks
    satans child's Avatar
    project...satans child
    Mar 2007
    button moon
    133
    cheers dave....
    hi twostrokepower i am still a member..
    ive been logged in all week but i have no pm from you???
    i still have my clocks .. pm me asap
    dave.. if i dont speak to you before the weekend have a good holiday....
    watch dem lions ..... have a wicked one bruv...
    Oct 2007
    131
    hello satan
    have just sent 2 pm to you please give me a call 01288 321 033 or pm me your moblie
    thanks
    simon
    jcb
    Sep 2005
    uk
    4,077
    i have some RS4 calipers and brackets for sale if anyone wants them. good nick.
    in the process of getting some adapters made up for B5 A4 hub carrier - B5 S4/RS4 caliper carrier
    just waiting for the spare hub carrier to arrive!!
