Volks AutosBadger5
Results 1 to 7 of 7
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    Rough Idle on 1.8T (AEB) engine
    Looking for some pointers on how the idle is up and down on my 1.8T engine. Engine runs fine but at traffic lights/junctions the idle drops and goes up and down. Not had it on Vagcom but will be looking to do so soon.
    Thanks in advance
    Craig
    Audi A6 2.5 5Cyl tdi Quattro running 180ps 370Nm @0.9bar soon to be over 200ps
    AUDI URS4, URS6 and A4 1.8T breaking Lots of spares available at good prices. Large parts require collecting.
    Biglockie's Avatar
    Aye you know it makes sense
    Nov 2006
    cumbria
    1,030
    idle speed control valve? either that or a MAF fault
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Check for vacuum leaks.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Could be a split breather hose as well as the above ^^^^
    There is a plastic hose under the intake that is like an L shape that can brake in the middle this was gone on my car and causeing a ruff idle and a bit of hunting.
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    cheers for the replies
    at the moment no EM light flashing up.
    MPG i am getting around 300 to 330mile to a full tank to about 20mile left on range. Is this about right for a standard car.????
    Craig
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Yeah thats good i get about that and somtimes i once got 360 that was with a dead turbo as well.
    Have a look at the hoses and that one under the inlet mani and then try and get VAGCOM hooked up.
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/showthread.php?t=43296
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    cool so not to far out with the MPG.
    Is there any point in changing the inlet manifold to the same as found on the Seat, VW. ( the one with the Throttle body at the end instead of the one like the URS4 AAN engine)
    Oh and the gearing is longer than i thought with 18" wheels in 3rd 105mph before limiter.......
    Craig
