EM TuningMonster Motorsport
    Apr 2004
    21
    Unhappy Change the bulbs-easy???
    Just had a call from my dad, he needs to replace a blown headlight bulb in his W-reg A4 tdi.
    Someone at his work has told him the front bumper has to come off just to change the bulb.....!!!!
    This can't be right can it..???????????
    Please help, because I know I'll get the job! lol
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    Er no. You should be able to get you hand behind the unit and change them that way. Worse case senario take the headlight out but not the bumper
    Built in Germany, Perfected in England
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    It's still a PITA though!
    Don't know if it's the same on the TDi, but the driver's side is much more difficult to do on an S4 because you need to remove the airbox to get to the back of the headlights.
    Good luck!
    Mo power, mo problems
    Apr 2004
    21
    Thank good for that, thought it sounded a bit over the top, even for Audi !
    Thanks for all your help guys!!!!!
    livlee1's Avatar
    Feb 2007
    essex
    54
    It's easy, done mine last week on a 99 tdi, on the drivers side just pull off part of the plastic airbox trunking to get to the headlight, no need for bumper removals or headlight removals..
