Badger5Chris Nott
Results 1 to 10 of 10
    Mar 2006
    Chester
    79
    A4 alloys - are these ok?
    Hi, the alloys on my 1997 1.8T A4 Sport are looking a bit scabby, so I bought a replacement set on ebay. They're a similar style, but from the later model (2002ish Sport).
    I hadnt realised that the offset on mine is ET45, and the new ones are ET42. I havent tried fitting them yet - does anyone know if they'll be ok?
    These are the replacements:
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    Your offset should be nearer 38 if i remember rightly.
    Built in Germany, Perfected in England
    Mar 2006
    Chester
    79
    Bloody hell, that was a quick response!! They're the original 5 spoke Audi Sport wheels, and they do have ET45 stamped on the back of them.
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    They should be fine but if they do rub a set of small spacers will sort it out so no problem.
    Oct 2007
    2,597
    @ ET 42, they'll be fine. No chance of rubbing, they'll fill out the arches more.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    higher ETs mean they will sit in further ,and risk more of touching calipers but if the old ones are 45s and new are 42 should be fine unless the spokes are thicker and nearer to the ET its self if you understand sorry
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    So what is the actualy correct offset on a 1997 1.8t as i thought it was 35?
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    Oct 2007
    2,597
    Quote Originally Posted by Markey
    All are ET45. 35mm offset was used on B4 Audi Coupe.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Will wheels with a ET35 fit ?
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/showthread.php?t=43296
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    I'm pretty sure mine are 35 and i've got 5mm spacers
