Badger5EM Tuning
Results 1 to 13 of 13
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    B5 S4 boost leak maybe?
    Hi just been fixing a chewed through washer pump cable due to driving the car with no arch liner in lol
    In the process i noticed some oil spray onto the bottom intercooler hose in front of washer bottle , could this be the reason for the maximum boost exeeded error and momentary limp mode if WOT particulary in higher gears ive posted before and checked pretty much everything with a pressure tester and n75,dvs,all pipes etc apart from wastegates on turbos because
    i cant get to them lol
    Please see pics
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Yup, that's a boost leak. Get it pressure tested. The oil will have been forced out by the pressurised air. Don't go WOT until you get it sorted!!
    Mo power, mo problems
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    I have already presure tested and didnt find any leaks im wondering if i didnt use enough pressure i will try again with a garage airline rather than my noisey 5 litre compresor lol
    Feb 2007
    Liverpool
    1,693
    You need to pressurise up to 15psi. Don't go any higher than that as you can cause damage.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    I will have to try again see what happens
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Is there any oil round the bottom of the pipe or is all just over the IC ?
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    i'd suggest that it isn't a big enough leak to cause a max charge pressure exceeded fault but as Blue Thunder says it certainly needs investigating as these things rarely fix themselves, i've come across 2 intercoolers recently that were leaking oil and neither threw a code so you may have another problem as well.
    could just be it needs the hose clamp tightening.
    when i do a pressure test i use the tyre on the car as a pressure source as it's silent so you can hear the leak, just keep pumping the tyre back up. a one way valve in the airline helps also by stopping the air leaking back out.
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    thats a awesome idea , im gonna do that instead , will this check the wastegate lines too
    Feb 2007
    Liverpool
    1,693
    The wastegates on a turbo are on the exhaust side, so you won't be able to pressure test that. You should run some vagcom logs on Block 115 to check your specified and actual boost. If the actual is significantly lower than actual, it's possibly a problem with the wastegates or N75.
    Not too sure you can actualy check the wastegates without removing the turbos.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    I dont have much free time is there anyone in the northwest that you know of who could check and fix the problem?
    shineydave's Avatar
    Jan 2006
    912
    i'd agree with that, i can't even see the damn turbos without the aid of a mirror.
    Dave
    shineydave's Avatar
    Jan 2006
    912
    PM Grizz on RS246, his garage is in the Wirrell somewhere, he may be able to help
    Dave
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    ok thanks i will do that ,its only held full boost for about a month out of the 5 years i owned it because of numerous boost leaks , egts,mafs,n75s etc lol
