Volks AutosJMB Retrofits
Results 1 to 7 of 7
    Danielson's Avatar
    Jun 2004
    UK
    704
    rear shock problem, HELP
    alright gang, started to hear a slight knocking coming from the nsr. had this before and it turned out the original shock was leaking and well past its best. so i replaced both rear shocks and the bushes in the rear while i was at it, and all was good.
    so these replacement shocks must have been on the car for 2 years max, and now i find this knocking noise to come back, i just jacked her up and i can lift the wheel up a good couple of inches with very little effort and it looks like it is also leaking. for comparison i tried the other side and it has much more resitance but also looks like its leaking a little bit.
    ARSE
    could one of you fwd b5 owners please jack up the rear and see how easy you can compress the shock/spring. surely i shouldnt be able to compress mine so easy.
    waveform2's Avatar
    * J e d i *
    Oct 2004
    Scotland
    435
    Dosent sound right mate cant help im afraid quattro.
    1999 A4 1.8 Turbo Quattro Sport - Xenons - Magic Tree
    Now gone:
    2000 A4 1.8 Turbo Quattro Sport - 18" RS4s - Xenons - Remapped 210+bhp - +More - Went bang now dead.
    1998 A4 1.8 N/A SE - 18" RS6s - Xenons - Angel Eyes - Fully Colour Coded - Lowered - Full Stainless Exhaust - +More - Writen off by a twit in a rx8
    My Current 1.8T Quattro Sport
    Oct 2007
    2,597
    Mine's quattro.
    But, I'd check that side again, and make sure the washer on the damper piston hasn't gone through the top retainer.
    joost's Avatar
    Nov 2005
    Lancs
    1,166
    I could hardly move mine - ended up trying to lift the wheel slightly when I was checking clearance on the rear strut a couple of weeks ago.
    Are you sure it's the shock and not the spring? I may be wrong but I would have thought the spring would provide the resistance against the wheel moving up, the shock merely damps the bounce?
    Justin
    2001 VW Golf 2.3 V5 (170) Highline, Indigo Blue - standard, for now...
    A4 (B5) SE with a few slight amendments here and there (sold)
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Shouldnt be easy at all mate, its what my last lot of shock/spring ended up like.from memory its what mine was like when mine blew as all of the shock oil had been spread over south wales,lol.
    Its what prompted the swap to coilovers
    Oct 2005
    lebanon
    92
    what is the difference between the rear shock of the Facelift specialy the mount and pre facelift , and is they interchangable?
    Danielson's Avatar
    Jun 2004
    UK
    704
    ok peeps, little update!
    As the ole bus is due her m.o.t on tuesday i thought i best get this rear shock knocking/leaking sorted.
    So i order a set of dampers for the rear, go to fit them and see the spring had snapped on the ns, oh dear i said! so a quick call to gsf and they can get me a set of 40mm lowering springs the next day, turns out they were exactly the same size as my old lowering springs, so ive just fitted the rears at the mo, the car feels like new, the difference is shocking! sorry couldnt resist the pun, =) so fingers x she should fly through the m.o.t as ussual.
