Chris NottEM Tuning
Results 1 to 9 of 9
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    2000 RS4 Brake setup onto 1996 A4 1.8T
    What is involved to get the RS4 setup onto a A4 1.8T sport?
    Also does the RS4 suspension also fit the car.
    Craig
    Audi A6 2.5 5Cyl tdi Quattro running 180ps 370Nm @0.9bar soon to be over 200ps
    AUDI URS4, URS6 and A4 1.8T breaking Lots of spares available at good prices. Large parts require collecting.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Im almost 100% certain the suspension will not fit because the RS4 has quattro etc
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    macca's Avatar
    Sep 2006
    Sussex.
    525
    i think the front bearing carrier is different on the s4 and rs4
    1998 A4 1.8T Sport - For Saturdays
    2003 VW Golf MKIV R32 - For Sundays
    2000 Peugeot 406 HDi - For when it's raining
    1996 Kawasaki ZX7R - For when I'm late for work!
    Mods- Forge Dump Valve, The Engine Shop Power Plus based Engine (Low Comp. Forged pistons, Arrow H-Section Rods, Newman fast road cams, polished & ported head), 19" wheels, B&M Short Shifter, Greddy Turbo Timer, RS4 Grill, Weitec GTN coilovers, HKS modified air filter, Autobahn88 FMIC, ChippedUK custom map. Some Turbo mods ongoing.
    jcb
    Sep 2005
    uk
    4,070
    hub carrier is different, track width is different and the caliper carrier bolt holes in the hub carrier are different between A4 and S4/RS4.
    The suspension may fit, I say this as the KW V3 coilovers I have are listed as the same model for A4/S4/RS4 although the height adjustable bit may mean that they fit when others wouldn't
    brakes don;t fit straight on but I am working on it!!
    360mm B5 RS4 disc and caliper, bolts straight onto an S4 hub carrier
    same S4 carrier with 360mm B5 RS4 disc and 4 pot lug mount brembo showing flange adapter needed.
    18" RS6 wheel with above set up ; )
    Sep 2005
    London
    197
    I tried this years ago - from memory the splines are different on Quattro driveshafts, especially between S4/RS4 and lower models; meaning you can't fit the hubs. You may be able to swap to Quattro drive shafts if the CV cup bolt pattern is the same on your gearbox.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,824
    Hi Stewart,
    Long time no hear what brings you back?
    So when you say the splines are different are you saying the 1.8t spline will not fit in to the RS4/S4 hubs or that they will not bolt up to the 1.8T flanges?
    Sep 2005
    London
    197
    Hello Dave! I've got an S3 at the moment.
    In answer to your question; the S4 uses a larger front wheel bearing than FWD models, and has a larger diameter drivehaft (more, larger splines compared to FWD).
    I never tried a non-S4 Quattro shaft in an S4 hub - they may fit.
    Mark
    K7ERG's Avatar
    Aug 2003
    Bridge of Earn
    350
    Thanks for the replies
    Tonight i checked and caliper mounting holes are different as i was going to use the RS4 calipers i have but suspension looks very similar.
    Going coilovers now
    Craig
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,824
    Quote Originally Posted by mwstewart
    Mark
    S3 nice..
    I will have to find out if the 1.8t Quattro drive shaft will fit as I have the full RS4 setup and was planning on fitting it to my 1.8t. I was aware the drive shaft did not bolt up to the 1.8T gearbox flanges and just assumed the T drive shafts would fit. This will put a spanner in the works if they dont and I will have to wait till I get my 6 Speed box.
