Chris NottAH Fabrications
    Sep 2007
    27
    cant open my bonnet
    as above had a little dink last week and now i cant open my bonnet any ideas how i can open it with out causing too much damage
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    piece of wire through grill hook onto lhook on lever and pull unless it wont pop at all if not check the metal colar seat in the plastic handle hasnt come loose if yes hold plastic outer and pul metal cable with pliers
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Jimbo.King's Avatar
    Oct 2006
    Leeds
    183
    Pull the bonnet release from inside the car while someone else pushes and pulls slightly on the front edge of bonnet to try and release the catch.
    2007 A4 3.0tdi Quattro S-line, Lava Grey Pearl, 229+bhp, 6 speed manual, Cruise control, Auto wipers/lights, Parking sensors all round, RNS-E Sat Nav, Heated Volterra leather, Adaptive Bi-Xenon plus headlights, Bluetooth phone prep/voice control, DRL, i-Pod dock, Coming home lights, A4 B5 front spring seat mod, LED DRL/side light/numberplate lights, Window tints, Cupra R front splitter, Black front grill, 3.5" custom tail pipes, 8.5x19 Calibre Excalibre wheels running 225/40/19, ET30-R ET35-F.
