mattsavage
Year 2000 Audi A4 1.9 Tdi PD
Hi. I serviced our Audi yesterday, changed the oil and filter, changed fuel filter, changed air filter, checked brakes, tightened slightly loose rear wheel bearing and that was all I did.
Then, I start it up, give it a few seconds to idle then I went for a drive.
No power! Just as if the turbo was not doing anything. I've had this before and it was the air flow meter, so I disconnected that, and still no power.
A while ago I brought a diagnostic reader. So I plugged this in and it came up with,
VAG type 5 digit - 17964
P type - P1556
When I look up 17964 it tells me,
"Turbocharger pressure - upper limit exceeded"
and says the problem could be,
"Turbocharger wastegate regulating valve, intake leak, Turbocharger defective"
All I did was change the filters!!
Has anyone had this problem before? I'm guessing it's something simple.
Any help much appreciated.
Thanks,
Matt Savage
P type - P1556
Thanks,
Matt Savage
