JMB RetrofitsAH Fabrications
Results 1 to 10 of 10
    Oct 2005
    lebanon
    92
    Exclamation interior light problem...
    Hi all ,
    my interior light doesnt works when ever i open the front doors , first it was when i open my door doesnt light even the other 3 doos works well , yesturday i found none of the front doors make it light , any tips help for this issue? it still works if i open the rear doors..
    any help will be appreciated.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    sounds like both switches are either faulty or getting corroded just bridge the connection to test the switch and cable on each side
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Oct 2005
    lebanon
    92
    where does those switches located? could u help me :S
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    you know ive never actually found them lol im sure someone knows where they are located
    Sorry i cant help
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    mine does the same. drivers door opening doesn't turn on interior lights. took off the door card, when moving it around the light and headlight warning beep comes on and off, but when fixed back in postion they don't work, there's a moody wire/connection somewhere but i'm buggered if i can find it! so any help would be appreciated too!
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    switch is in the door lock mechanism, never had one out so i can't help further, sorry
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    Oct 2005
    lebanon
    92
    lol , i thought u geuss where is it , if i could find them i wouldnt be asking, maybe they are in the locks , i must take the door card of and trace them , so Stapo69 you have same symphony as me , but now both doors doesnt make the light come , before it was just my door i must found that soon.
    please if some know let us know , ill appreciate that a lot!
    Oct 2005
    lebanon
    92
    aha , so i must take the lock apart and see what with it... maybe water get in when i watch the car in the station and they die later...
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    mine is the same drivers door intermitant , i have a aftermarket alarm and senses there is a door fault with a extra beep i give it a good slam and seems to sort it for a week or so, really need to get it sorted tho
    shineydave's Avatar
    Jan 2006
    912
    Quote Originally Posted by kninio
    as i stated above the switch is in the lock, it's actually a part of the lock mechanism
    Dave
