Monster MotorsportChris Nott
Results 1 to 12 of 12
    macca's Avatar
    Sep 2006
    Sussex.
    525
    Help: Car won't start
    Ok, this has really got me, I have ran VAG-COM but no errors, replaced battery, check i have a spark on all plugs, fuel is going in, but car just turns on starter and makes no effort to ignite.
    does anyone know if the car runs or starts, albiet rough, if you disconnect the Air flow sensor?
    I can vag-com the ecu, no errors, does this mean the ecu is ok, or should i suspect this still? are there any immobiliser issues known on the a4's?
    the car is a 98 a4 1.8T
    cheers
    1998 A4 1.8T Sport - For Saturdays
    2003 VW Golf MKIV R32 - For Sundays
    2000 Peugeot 406 HDi - For when it's raining
    1996 Kawasaki ZX7R - For when I'm late for work!
    Mods- Forge Dump Valve, The Engine Shop Power Plus based Engine (Low Comp. Forged pistons, Arrow H-Section Rods, Newman fast road cams, polished & ported head), 19" wheels, B&M Short Shifter, Greddy Turbo Timer, RS4 Grill, Weitec GTN coilovers, HKS modified air filter, Autobahn88 FMIC, ChippedUK custom map. Some Turbo mods ongoing.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    check plugs for spark and wet from fuel if wet and no spark its defo a ignition fault , immobilisers usaually start then die
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    oh and yes they run without maf pluged in but just ruff
    macca's Avatar
    Sep 2006
    Sussex.
    525
    yeah i have wet plugs and strong spark but just nothing, weird.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Temp sensor. Thats what stopped mine from going. I changed the plugs from the Bosch super 4's and put a new temp sensor in, and she has worked well since
    macca's Avatar
    Sep 2006
    Sussex.
    525
    which temp sensor? where is it? i've checked woth vagcom and i haven't had any faults logged.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Was the car running fine before or have you just done some work on it?
    It does sound like an immobiliser problem. Have you just had your ECU reprogrammed? I've heard of them 'locking out' if the remapping software doesn't close down properly. It effectively crashes your ECU.
    If you've not done anything with the ECU, you're getting fuel and a spark but no bang, the only thing missing is air. There's no chance you've got a seized turbo is there? That would prevent air getting sucked into the inlet manifold.
    Mo power, mo problems
    macca's Avatar
    Sep 2006
    Sussex.
    525
    nothing done (well apart from fitting coilovers just before hand, but not gone near electrics, apart from undoing suspension top near ecu, but car used since then), car started fine in the morning, got home from work, just wouldn't start. no problems leading up to this one either.
    i'll check turbo tonight but i'm sure that is ok. ecu is completly standard so nothing untowards there i hope.
    i have now official broken my maf while cleaning it so i need to get another one from somewhere first, damn it. they are very delicate indeed, unless that was a problem to start with (which i doubt)
    Feb 2007
    Liverpool
    1,693
    If the car was running fine in the morning and nothing has been done to the engine I'd ignore my scaremongering!
    I know you said the spark plugs are wet, but not so long ago I had a blown fuse for my Fuel Pump. The engine turned over, but there was no ignition whatsoever. I'd check your fuses before anything else.
    macca's Avatar
    Sep 2006
    Sussex.
    525
    done that :-) and the relays, fuel pump is running when starter turning over. learnt that from owning golf gti's
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    have you a spare master key ,if so try that if not swap battery in fob just to verify it aint that , and also disconnect the battery for an hour then re attach and leave the key on the ignition on setting for 25 mins then give it another try , when doing this you should hear some light buzzing from under the bonnet if not then check the fuel pump regulater and return to tank valve
    macca's Avatar
    Sep 2006
    Sussex.
    525
    spare master key i've tried, disconnected battery for 24 hours. haven't tried the ignition thing, i guess that us the throttle body allignment thing which i believe i can get vagcom to do?
    will try regulator and return valve, where is the return valve, near the fuel rail?
