    Jan 2004
    united states
    Head swap on 2.7T with a 2.8 head, anyone ?
    Looking into adding upper RS intake pieces like Mani/TB and cams and while the RS4 heads are not worth the cost wanted to know if anyone has had any success with adding 2.8 heads ? From what I heard from one person everything should bolt up fine with the rs4 parts as well as the 2.8 heads have slightly larger exhaust valves as well. Plus, don't the heads come with cams ? Wonder if the cams would have to be swapped out ?
    Any advice is appreciated. !!
    Aberdeen
    153
    Re: Head swap on 2.7T with a 2.8 head, anyone ?
    OOOOoo that's a biggie. Not sure. Yes the official Audi techs manual does say that the heads of the S4 are similar to the 2.8. In fact here is the text directly from said manual:
    The cylinder heads are largely identical to those used in the V6 naturally aspirated engine. Common parts are used for both banks of cylinders.
    The mounting position of the right-hand cylinder head is rotated through an angle of 180 in relation to the left-hand cylinder head. The timing of the inlet camshafts is enginedependent. To improve heat dissipation, the exhaust
    valves are sodium-filled.
    The variable valve timing
    The camshaft timing has been modified
    compared to the 2.8-litre V6 engine to meet the
    demands of turbocharging technology.
    Variable valve timing with an adjustment angle
    of 22 is used here for the first time in
    turbocharged engines
    Advantage:
    A torque increase of approx. 10% is
    achieved at the bottom and top ends of the
    engine speed range.
    Better emission levels and fuel
    consumption figures.
    The variable valve timing is activated by the
    Motronic by means of camshaft adjustment
    valves N205 and N208.
    The RS4 tech manual mentions the entire valve system has been redesigned. The exhaust ports are reported to be smaller.
    Sorry not really much help. We are awaiting the official RS4 one.
    Jan 2004
    united states
    Thanks for the info.
    OK, so the cam timing is changed to increase torque on the 2.7T. From what I have been able to gather, the 2.8 heads mimic the rs4 heads in cam profile, intake port and exhaust port. I thought I read somewhere that the exhaust valves on the 2.8 heads were slightly larger but the exhaust valves themselves were not sodium filled like those on the 2.7T
    In any case, sounds like these heads will work just fine, bolt right up etc. Now I just need to track some heads down and get some pricing. JG
    Aberdeen
    153
    Re: Thanks for the info.
    Sounds like an interesting project. Let us know how you get on. - Good luck
    Aberdeen
    153
    nice article [img]/ubbthreads/images/graemlins/smile.gif[/img]
