EM TuningChris Nott
Thread: s4 clutch
    Apr 2007
    Surrey
    235
    s4 clutch
    Hi. I have started getting some clutch judder in first gear when pulling away. It is more apparent if i am gentle with the acceleration. If i lift the clutch at 2000 rpm and above it seems ok but under this and it judders a bit. Is this something to be concerned about and if I will need a new clutch can anyone advise on the best people to contact as Audi claim it is about 8 hrs to get to it and not up for that sort of cost.
    2003 S4 Moro Blue Saloon
    GSB1's Avatar
    May 2006
    UK
    273
    Visit GSB1's Youtube Channel
    Well the clutch shouldn't judder and judder in the circumstance you describe is a sign of wear so far as I know.
    Unless you have a stock car power wise and are planning long term to keep it that way an RS4 clutch makes sense.
    Eitherway a suitable inderpendant specialist is what you require.
    From Surrey, I am not sure who is the closest, but the ususal suspects spring to mind as reasonable travel - QST, MRC, APS, Dialynx. Personally have only used MRC and APS, both very good.
    Present: Ice silver B8 S4 s-tronic saloon (standard)
    Past: Agate grey B5 S4 saloon (MRC tuned)
    Hers: Volcano red 8P A3 Sportback 2.0 TDI CR 170 sport quattro
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    Are you sure it's the clutch and not worn engine or gearbox mounts?
    Either way, it's not sounding like it will be a cheap resolution... welcome to the world of the S4!
    Mo power, mo problems
