AH FabricationsEM Tuning
    Oct 2007
    Exclamation Engine Problems!!
    I have a 97 1.8t quattro.
    When i am coming to a stop and i push in the clutch the rpms drop below 1000 and start to go up and down between 500 and 1100, it does the same thing if i rev the engine and it sometimes happens when i turn the car on. It feels like it wants to turn off but it doesnt. It only last about 10 secs but it is really annoying. Im also getting alot of hesitation when i lay on the throttle but if i let off and hit it again it will accelerate fine.
    I replaced the spark plugs with the factory specified ones about 2000 miles ago and the MAF about 1000 miles ago.
    thanks for your help.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    Perhaps a dodgy EGT or Lamba sensor. Best thing is to check for fault codes on vagcom.
    Mo power, mo problems
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    the Throttle Position Sensonr on fords, and the Idle Control Valve both cause this.
    1999 1.8 SE A4 100% standard tank, all green.
    Alpine old skool
    Helix RS6 - PHD PRO 4070
    Coral 10" passive setup - PHD 2200
    Biglockie's Avatar
    Aye you know it makes sense
    Nov 2006
    cumbria
    1,030
    aye the idle controller clogs up with gunk usually just need removed and cleaned out with a solvent cleaner or petrol
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Quote Originally Posted by Biglockie
    Fairly easy job to undertake by yourself, as long as your carfull and not heavy handed.
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,309
    where is it located please guys? pics would be awesome
    Thank you ..
