diarmuid
Hi All,
I haven't been on this forum for a while but hopefully someone will be able to offer me some advice regarding my air con system.
I checked my car (1998 A4 1.8 SE) in a few days ago into an independant as I was having throttle problems (the car was cutting out). It turns out that the throttle body was full of gunk and they reset the throttle settings etc. However, they also replaced the water pump, changed the belts (as they were due and the front end was off) coolant sensor as well as a few other small things. Ended up costing me £400 though.
When I went to pick up the car it turns out that they disconnected the air con clutch belt (ultimately leaving the aircon unworkable) as they said that the air con was making lots of noise and they were afraid that it would fail and the bearings would mess with the radiator and the rest of the car etc. (it would have been nice if they told me that they did this before I picked the car up!).
The thing is I've had the car for 4.5 years and it has always been 'noisy' and it has always worked perfectly. They said that get a new unit fitted/gassed etc. would cost about £1,500.
When I said that I might take my chances as I would like for the aircon working (including for when if I sell the car in the future). They then told me that maybe I should replace the aircon clutch and they will get a price for me tomorrow.
At this stage I'm not sure if I should just tell them to put the belt back on, get them to change the aircon clutch or just live without the aircon. To be honest I'm leaning towards just putting the belts on as it has always been noisy and it has always worked.
I'd appreciate any thoughts any of you have on this.
All the best,
Diarmuid
All the best,
Diarmuid
