Monster MotorsportEM Tuning
Results 1 to 8 of 8
Thread: EGT VALVES
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    EGT VALVES
    Hi been running low boost and high fuel for a while now and just got round to vag com ing it. I pretty sure its was one of the EGTs as this has happened before.
    This is my read out my question is which side is it when looking into the engine bay from the front?
    Also wheres the cheapest to buy EGTs?
    many thanks in advance
    Address 01: Engine
    Controller: 8D0 907 551 C
    Component: 2.7l V6/5VT G 0002
    Coding: 05611
    Shop #: WSC 00337
    1 Fault Found:
    17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
    P1454 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes
    Controller: 8E0 614 111 A
    Component: ABS/EDS 5.3 QUATTRO D00
    Coding: 0273004284
    Shop #: BB 24334
    1 Fault Found:
    00290 - ABS Wheel Speed Sensor: Rear Left (G46)
    35-00 - -
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    i'm pretty certain that one is the drivers side (right hand side) one, it's not a valve BTW but a sensor
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    Yeh sorry sensor yeh that would make sense as it was the other side which failed last time. But you say drivers side but also the right hand side im a little confused or are you talking euro drivers side ?
    Is it just me or are most of the sensors and valves rubbish i seem to of replaced nearly all of them at one stage or another?
    Please could i have a backup that its the drivers side before i shell out mega money for pretty much nothing
    macattax's Avatar
    Oct 2006
    Ireland
    451
    He said drivers side which is on the right hand side when you are sitting in the car not while looking in the engine lol.
    FACELIFT 99.5
    Current Mods: RNS-E MMI Conversion,Carbonio CAI,
    Baileys DV30 valve, Tinted windows, Xenon H.I.Ds, Bosch Aerotwins.
    Planned mods: Rieger Kit,Engine Tuning, Leather sports seats.
    Accomodation when the missus kicks me out for wasting money on a car.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    that will do me thanks , best get my money out but atleast it will be easier to install this time
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    I replaced EGT 2 on the passenger side, so i think you're right, got mine from vagparts.co.uk, about the cheapest I could find, genuine parts too, just took a few days to come as they get em straight from germany, unless they happen to have any in stock at the time.
    Also sensor 1 is loads easier to replace, can get to it through the engine bay, can see it pretty easy in the top of your downpipe just a little further down than you're lambda, sensor 2 was a lot harder, ended up borrowing some ramps cos you can't do this one from the top. Cetainly made a hell of a difference to the car once it was done though.
    Dunno if this is any help to ya:
    http://www.audiworld.com/tech/eng73.shtml
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    Thanks for clearing that up i read that the last time very good post. I will try vag parts now
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    Finally got round to fitting new EGT sensor and got my boost back feels awesome only thing is it dropped its boost for a second or two into limpmode and vag said upper boost limit exeeded i have checked for leaks again and none present im now thinking sticky wastegate any ideas how to check as its very hard to get to them , B5 S4 by the way
