    Mar 2007
    Leeds, UK
    74
    Can't restart diesel after run-away
    Two weeks ago, after an oil change and turbo clean the engine on my 1997 1.9 TDI ran away. It revved out of control for about 20 seconds and then the auxiliary belt snapped. The engine then gently died.
    Having replaced the belt and VAG COM'ed it I have not been able to get her to start.
    The engine turns over nicely on the key but will not fire. I have had all 4 injectors out, cleaned then and bled them, but still she won't fire.
    Has anybody ever experienced this and is there anything I can do.
    All help very much appreciated.
    Cheers,
    Beef
    enda1's Avatar
    Jan 2006
    Ireland
    439
    Get a compression check done on the cylinders. If you are low on compression then it probably won't fire
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
    Mar 2007
    Leeds, UK
    74
    Thanks Enda, I'll get that sorted.
    Cheers,
    Beef
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Yeah mine is not a diesel but had the exact same problem would run on the key, found out after a compression check there was none...
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
