Sky InsuranceJMB Retrofits
Results 1 to 13 of 13
    Aug 2007
    87
    ABS Warning Light On, but no fault
    Just got my A4 2.8 Quattro back from service, they could not find out why my ABS warning light is coming on as typically it did not do it why they had the car. The computer did not show any faults with the system. As I was leaving it came on so I showed the guy and he plugged the computer back in. This time it would not access the brake system. He said the most likely cause was a faulty ABS control unit. Apperantly these are 400! Anyone had the same problem, I am hoping there is a cheaper / different solution!
    Thanks in advance!
    simonwjones's Avatar
    Aug 2005
    staffs uk
    351
    not had the problem, but the first thing I would do is to unplug the cable off the sensors, spray some contact cleaner on them and put them back on.
    Failing that it could be a faulty sensor or even broken or bent abs ring
    Give it a try first before spending that sort of money
    Simon
    A6 3.0TDI Quattro Avant Le Mans
    A6 2.5tdi Quattro Sport 180 Sadly Missed
    A6 1.9tdi Avant ................. Gladly missed
    A6 2.8 Quattro .................. Sadly missed
    Quattro 2.8 Coupe ............. Sadly missed
    SatNav, BT, AMI, DAB
    Aug 2007
    87
    where are the sensors?
    Aug 2005
    staffs uk
    351
    Not and A4 but should give you a general idea of what to look for
    http://www.audipages.com/Tech_Articl...eshooting.html
    Simon
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    I have the same problem, was told ABS module will be faulty, got recommended these to sort the problem, get it resoldered for 100, a lot cheaper than a whole replacement unit that you don't need, and their turn around is nice and quick, they say 48hrs.
    Also you won't be able to get access while the fault light is on either, it blocks it. I got this fault when I managed to read it and this confirmed the problem.
    1 Fault Found:
    01203 - Electrical Connection between ABS and Instrument Cluster
    03-10 - No Signal - Intermittent
    Give em a try.
    http://www.ecu-testing.com/
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    Aug 2007
    87
    thats great, thanks :D
    where is the module located in the car? Is it realitivly easy to remove and refit?
    Apr 2007
    Bath, UK
    30
    Fairly yes, need to get mine done too as I got similar fault:
    http://www.audiworld.com/tech/elec116.shtml
    Another place to buy:
    http://www.bba-reman.com/
    98 Noggy Blue S4 Avant - RS4 Suspension and ARBs - DTS - Miltek - 18" Nuvolaris - ECS Stage IV - 710n - Quickshift - AWE Vent Boost Gauge - MRC Custom Map - 315BHP with 355 ft/lbs
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    ...Or maybe try the repair yourself???
    http://passat-b5.ru/index.php?option...=296&Itemid=57
    At your own risk though!
    Si.
    2000 1.8t quattro Sport totally standard (ish)
    stapo69's Avatar
    Mar 2007
    966
    Bit of a job to do yourself, unless you're an electronics expert, all silicone sealed chip boards that need resoldering apparently, not an amateur fix I don't think.
    The module itself is located on the side of the ABS pump on the right hand side of the engine bay, black box bolted on with a large connector block clipped on the bottom of it.
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    Worked for me, and I'm stupid and a right cack handed tw*t
    Si.
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    Had the same problem with my S4, thought about doing it myself, and I have been soldering for years, thought better of it and got it professionally repaired instead. ABS is a safety item after all....
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    It's EXACTLY the same procedure as they do...
    Si.
    stapo69's Avatar
    Mar 2007
    966
    Just thought I'd mention that I sent the module to ecu-testing.co.uk on monday, they rang me today and it's fixed and will be back with me tommorrow, damn quick service I reckon, well worth using them.
