AH FabricationsEM Tuning
Results 1 to 16 of 16
Thread: Help!!!
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    Help!!!
    Havin probs with my S4, again! Surprisingly! When I start it up, it idols badly, hunts around the revs up and down and eventually stalls, if you give it any gas it just won't go, coughs splutters and dies.
    Thing is with MAF unplugged it'll idol fine, driveable but just with not a lot of go. So you'd think knackered MAF but had 2 brand new Audi units on it now and still no joy.
    Any ideas anyone? Anything? Before I bite the bullet and drop it off at Audi.....for them to empty my wallet!
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Where the errors cleared on the ecu after the new Maff was installed ?
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    stapo69's Avatar
    Mar 2007
    966
    Yeah cleared all the the codes, still ran like **** though sadly! Did get another code come up today though for 1 of the lambdas, the 1 I replaced about 3 weeks ago!!!! Got another one under guarantee to put on today so I'll see what happens then. Also got some other codes the other day, anyone shed any light on what thet mean?
    17965 - Charge Pressure Control: Positive Deviation
    P1557 - 35-10 - - - Intermittent
    17743 - Engine Torque Monitor 2: Control Limit Exceeded
    P1335 - 35-10 - - - Intermittent
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Quote Originally Posted by stapo69
    The above two reading on a couple of forums say that there could be boost leaks in the hoses or possible leakes in the vacuum hoses to the Diverter valve of the boost controll valve making the car not hold boost properly.
    I had this one the other day because the battery kept going flat from all the starting and stopping while the car was dead.
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/showthread.php?t=43296
    Jul 2007
    Leicester
    456
    ive got the same 'power supply' message come up on miens too.
    the battery has never been replaced and im thinking that might be the cause.
    looking in to getting a new battery soon. old one looks knackered.
    if you get it sorted before me let us know mate.
    stapo69's Avatar
    Mar 2007
    966
    Well, had the diverter valves replaced with 2 new 710n's and the car seems fine now, so I'm told by the garage, just gotta clear the codes and hopefully all should be well again, obviously the recent chip has taken it's toll on the weak links, so big deal, nice cheap fix, for once! Picking it up tomorrow so should feel if it's ok. Fingers crossed!
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Like i said above then
    stapo69's Avatar
    Mar 2007
    966
    Actually sadly no Markey. Went to pick up my car from the garage today and they'd not plugged the maf back in and when we did it was exactly the same! Ahhhhhhhh! Still idoling badly, no boost, drives like a bag of ****! Bloody cars! So any more ideas anyone? Anything?
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    Have you not replaced the MAF? A faulty MAF quite often throws random codes out.
    Also, with the 'Charge Deviation', i'd get a pressure test done somewhere sooner rather than later(asamfp). A boost leak recently killed my new K04's with less than 1,000 miles under their belt!
    stapo69's Avatar
    Mar 2007
    966
    Had 3 MAFs on it now, 2 brand new from Audi, so I'm thinking its not that, damn unlucky if it is! Geting all the pipes checked tomorrow, so a pressure test is on the cards I think.
    stapo69's Avatar
    Mar 2007
    966
    Was a boost leak, split hose somewhere, so all is well again, so I'm told anyway although I've drivn it yet!
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Thats a yes again then lol
    stapo69's Avatar
    Mar 2007
    966
    Yes yes Markey. Well spotted!
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    577
    I'd find a different garage to take it to next time...
    Sound like bloody amateurs to me. No offence like
    Si.
    2000 1.8t quattro Sport totally standard (ish)
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    I hope that it is all sorted for you this time when do you collect it ?
    stapo69's Avatar
    Mar 2007
    966
    Collected it today and it's all good, running sweet again, apart from a ticking noise from the top of the engine on bank 2, I'll investigate that further anoter day, could be worn cam chain tensioner maybe.
    Getting ABS module sorted 1st though.
    Plus investing in a full set of silicone hoses now though, try and avoid future problems like this, thats the 2nd hose to go in a few weeks, only just replaced throttle body boot.
